[Qgis-developer] Crash on exit
Andreas Neumann a.neumann at carto.net
Fri Sep 18 05:10:17 PDT 2015
Problem solved. Turned out that a plugin was causing the crash on exit.
Now I still have to find out why QGIS server is currently crashing on my
system.
Thanks,
Andreas
On 18.09.2015 13:37, Kari Salovaara wrote:
> yes, I do; Win 7 pro 64bit, makes smalldump
> It started to happen already last spring, it was looked a little at
> Nödebo but no solution.
> Kari
> On 09/18/2015 02:31 PM, Andreas Neumann wrote:
>> Hi,
>> Am I the only one who gets crashes on exit with QGIS current master?
>> These crashes happen on Ubuntu Linux 64bit, but also on Win7 64bit
>> (although the windows version is a bit older (3 days old)). But Linux
>> is up-to-date.
>> What can I do?
>> Andreas
