[Qgis-developer] Crash on exit
Andreas Neumann a.neumann at carto.net
Fri Sep 18 05:25:54 PDT 2015
It is not a plugin from the public plugin repository, but a plugin
developed by ourself from the waste-water project ;-) apparently it was
a known-problem - but I did not know.
Andreas
On 18.09.2015 14:23, Paolo Cavallini wrote:
> Il 18/09/2015 14:10, Andreas Neumann ha scritto:
>> Problem solved. Turned out that a plugin was causing the crash on exit.
> could you understand which one?
> thanks.
