[Qgis-developer] [QGIS-Server] Relative paths and QGIS-Server
René-Luc Dhont rldhont at gmail.com
Mon Sep 21 06:07:32 PDT 2015
Hi Devs,
Hi Marco,
I encounter some troubles with relative paths and QGIS-Server. For
example, SVGMarker path and NETCDF datasource are not resolved in QGIS
Server unlike in QGIS Desktop.
To resolve relative path for SVGMarker, the class QgsSombolLayerV2Utils
is used and it based on QgsProject::instance()->fileName().
To resolve relative path for NETCDF datasource and other GDAL
datasources, the class QgsMapLayer is used and it based on
QgsProject::instance()->readPath( filename ).
QGIS Server uses the QgsServerProjectParser to convert relative path to
absolute path. This mean that it parses the project and update paths.
To fixe this issue, we have 2 solutions :
* Set the QgsProject instance FileName in the QgsServerProjectParser
* Update QgsServerProjectParser::createLayerFromElement to resolve and
update SVGMarker path and GDAL datasources
Marco, I'dlike to have your point of view to fix it.
Regards,
