[Qgis-developer] proj.4 new codes
Even Rouault
even.rouault at spatialys.com
Tue Sep 22 01:21:01 PDT 2015
Le lundi 21 septembre 2015 17:29:51, Andre Joost a écrit :
> Am 20.09.2015 um 19:32 schrieb Paolo Cavallini:
> > On Debian sid we now have proj.4 4.9.2, which should contain also new
> > EPSG codes (namely 6707, and more). How can I get QGIS 2.10 know about
> > it?
> The usual way would be to run apps/qgis/crssync.exe (foldernames on
> Windows). But I assume it looks only into the GDAL files, not PROJ.4.
> It should not be a great problem, because GDAL 1.11.3 is just around the
> corner.
The EPSG database hasn't been updated in this maintenance release. You need
GDAL 2.0 for EPSG:6707
> HTH,
> André Joost
> Qgis-developer mailing list
http://www.spatialys.com
