[Qgis-developer] New API for labeling Engine?
HAUBOURG
regis.haubourg at eau-adour-garonne.fr
Thu Sep 24 01:24:14 PDT 2015
Hi Martin,
Thanks for your lights.
The idea is to write advanced QEP's by the end of the year. Then, we will try to fund coding on that roadmap (all is opened there). All good ideas are welcome for those QEP's. Oslandia is now funded on the QEP's part and will start the work and work on that at the hackfest.
Several parts of QGIS will be touched, from qgs format and ability to store data and ressources , labeling API up to UX design.
Cheers
Régis
> -----Message d'origine-----
> De : Martin Dobias [mailto:wonder.sk at gmail.com]
> Envoyé : jeudi 24 septembre 2015 10:12
> À : HAUBOURG
> Cc : qgis-dev
> Objet : Re: [Qgis-developer] New API for labeling Engine?
> Hi Regis
> On Wed, Sep 23, 2015 at 4:19 AM, Régis Haubourg <regis.haubourg at eau-
> adour-garonne.fr> wrote:
> > Hi all,
> > I just saw a recent commit labeled "New API for labeling engine
> > (QgsLabelingEngineV2)" [0]
> > Can anyone tell us more on that work that seems very promising?
> This was motivated by my work on rule-based labeling (landed just moments
> ago in master). The labeling engine has existed without major architectural
> changes for 5-6 years since its introduction. Since then lots of features were
> added and the original framework started to show its age. The new API
> should allow for much more flexibility... things like running labeling engine
> completely independently from the main rendering loop, using anything as a
> source of label features (e.g.
> raster cells?) and so on. The old API (QgsPalLabeling) is of course still available
> (and acts as a wrapper of the new API), but should get removed in QGIS 3.
> > My question is not totally innocent, I just launch funding to start
> > QEP's work on labeling improvements. I would like that QGIS can handle
> > several features, but need to fund exploratory work before knowing how
> > to do that
> > exactly:
> > - add core ability to draw callouts between features and labels
> > - add new label types, that wan be labeled on "paths", just like
> > ESRI annotations.
> > - port to C++ features currently available in EasyCustomLabeling
> > Plugins and Mask plugin.
> > - generate layers dedicated to manual labeling (addition of
> > data defined fields).
> > - Allow to mask labels outside of an area of interest, and
> > allow Atlas to use it in batch use cases.
> Nice list - let me know if you need help with any of those ;-)
> Cheers
> Martin
