[Qgis-developer] Metasearch throwing an error
Tom Kralidis
tomkralidis at gmail.com
Fri Sep 25 03:36:41 PDT 2015
On Fri, Sep 25, 2015 at 5:59 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Hi all,
> the current version of MS returns an error when adding default servers:
> Cannot parse XML file: not well-formed (invalid token): line 11, column 129
> When reinstalling, I get:
> Impossibile caricare il plugin MetaSearch a causa di un errore chiamando
> il metodo classFactory()
> Traceback (most recent call last):
> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 219, in
> startPlugin
> plugins[packageName] = package.classFactory(iface)
> File
> "/home/paolo/Scrivania/butta/carto_qgis/python/plugins/MetaSearch/__init__.py",
> line 28, in classFactory
> from MetaSearch.plugin import MetaSearchPlugin
> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 478, in
> _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File
> "/home/paolo/Scrivania/butta/carto_qgis/python/plugins/MetaSearch/plugin.py",
> line 31, in
> from MetaSearch.dialogs.maindialog import MetaSearchDialog
> _import
> File
> "/usr/share/qgis/python/plugins/MetaSearch/dialogs/maindialog.py", line
> 53, in
> from MetaSearch.util import (get_connections_from_file, get_ui_class,
> ImportError: cannot import name serialize_string
> Should I open a ticket?
Hi Paolo: I was able to reproduce this issue. The default CSW
connections list had XML errors. I have fixed this in master and
release-2_10 branches. I've also added this as a note on our guidance
page [1]. Can you confirm the fix works for you?
Thanks
..Tom
[1] https://hub.qgis.org/wiki/quantum-gis/MetaSearch_Default_Connections_List
