[Qgis-developer] QCA lib dependency for master
Sandro Santilli strk at keybit.net
Sat Sep 26 01:36:30 PDT 2015
On Sat, Sep 26, 2015 at 02:14:03AM -0600, Larry Shaffer wrote:
> Hi Sandro,
> On Sat, Sep 26, 2015 at 12:47 AM, Sandro Santilli <strk at keybit.net> wrote:
> > Larry, I noticed that the ssl plugin is mandatory if you enable
> > tests. While I do understand that tests exist for using the SSL
> > plugin, should that be a recommended but not mandatory dependency ?
> Ok, that should be fixed with dd9b37b. Tests are skipped if the qca-ossl
> plugin is missing. It should not be a mandatory dependency.
Thanks. It would still be nice to print a RECOMMENDED warning.
> > I hadn't tried disabling QCA completely, but it should be checked
> > if it still allows enabling tests.
> Not sure I understand what you mean by 'disabling,' or why doing that would
> be useful for testing. It won't compile if QCA is missing (won't configure
> either, just like other required libs).
Ok, I thought QCA was still optional, no problem then.
--strk;
