[Qgis-developer] QGIS Master crashes on exit
Casper Børgesen (CABO) CABO at NIRAS.DK
Mon Sep 28 02:46:23 PDT 2015
Hi Nyall and Salvatore.
I have made a manual install of the nightly build from OSGeo4W and now I have a newer revision and no crashes so far. So problem solved.
I do a quiet update of my nightly build each morning using the OSGeo4W installer, and something must have gone bad, since the installer didn't wanted to upgrade my previously install. But again problem seems solved, so no reason to dig further into that.
Thank you for confirming the my previous nightly build installation was too old!
Regards, Casper
-----Original Message-----
From: Nyall Dawson [mailto:nyall.dawson at gmail.com]
Sent: 28. september 2015 11:18
To: Salvatore Larosa
Cc: Casper Børgesen (CABO); qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] QGIS Master crashes on exit
On 28 September 2015 at 18:35, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> Hi Casper,
> On Mon, Sep 28, 2015 at 10:04 AM, Casper Børgesen (CABO) <CABO at niras.dk> wrote:
>> Hi!
>> I’m using QGIS master x64 from OSGeo4W, and I’m experiencing crashes
>> (with
>> minidumps) each time I exit QGIS (including if I just open and closes QGIS).
>> I don’t know how to extract a stack trace from the minidump (if it
>> has one?) and renaming the “.qgis2” folder doesn’t help.
>> I have just updated the my MASTER edition from OSGeo4W, based on
>> revision c7a3ea3, but I haven’t found a build date for that revision.
>> The “qgis-dev-bin.exe” has a modified date of September 16, 2015, but
>> I would expect it to be newer by now?
> the date of your revision is a couple of weeks ago (15 Sep), in the
> meanwhile a lot of fix have been pushed Please try a more recent
> revision, the crash should disappear.
Also try disabling plugins - a crash on exit can be caused by a bad plugin.
Nyall
> Thanks,
> -SL
>> I could open a ticket describing the problem, but I’m not sure where
>> the problem is? QGIS code or OSGeo4W builds?
>> Can any give me a hint?
>> Regards, Casper
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
