[Qgis-developer] processing algoritm/script button?
Richard Duivenvoorde
rdmailings at duif.net
Mon Apr 4 09:45:57 PDT 2016
Ah, cool.
Thanks! This was what I was looking for!
Regards,
Richard
On 04-04-16 13:21, Victor Olaya wrote:
> Right, and, as Alex points out, doint it programatically you have the
> option to add a button as well (using the UI, not)
> see https://github.com/qgis/QGIS/blob/master/python/plugins/processing/gui/menus.py#L138
> 2016-04-04 13:18 GMT+02:00 Alexander Bruy <alexander.bruy at gmail.com>:
>> Hi Richard,
>> as Victor already mentioned, you can add menu entry for any
>> Processing algoroithm via Options dialog.
>> If you want to do this programmatically you can use
>> addAlgorithmEntry() function from processing.gui.menus
>> package.
>> 2016-04-04 13:35 GMT+03:00 Richard Duivenvoorde <rdmailings at duif.net>:
>>> Hi,
>>> tried to Google this but did not find anything yet. But having a
>>> (custom, complex) processing script, what is the best/easiest way to
>>> give it it's own button on the toolbar?
>>> I could write a minimal plugin to call the algorithm?
>>> OR does processing already have this?
>>> And if not: this is the feature request: ;-)
>>> Given one or more Processing scripts, make it possible to place a button
>>> in the processing toolbar (not yet there...) for it.
>>> Maybe via some syntax like
>>> Where foo.jpeg is an image next to the script? Or full path to it
>>> As a tooltip you could see the name of the user script?
>>> If not already there it could create a 'processing scripts button
>>> toolbar' and add the button to it.
>>> Upon clicking the button it would run the script.
>>> One script can have one button.
>>> In this way the user-friendly-ness of a plugin could be combined with
>>> the (for end users sometimes) rather 'technical' view of a processing
>>> script. Especially for those users who only run a couple of specialized
>>> scripts this would be nice.
>>> Regards,
>>> Richard
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Alexander Bruy
