[Qgis-developer] Warning from DigitizingTools about CRS mismatch
Bernhard Ströbl bernhard.stroebl at jena.de
Fri Apr 8 02:37:51 PDT 2016
Hi Casper,
no idea why they behave differently. Are the settings for the layer's
SRS on both machines the same?
As I wrote, the warning is shown if there is a missmatch in the
project's and the layer's SRS-id.
Bernhard
Am 08.04.2016 um 11:13 schrieb Casper Børgesen (CABO):
> Hi Bernhard
> Thanks for your answer.
> Yes I know that QGIS tries hard to determine the SRS-id which matches the values of the PRJ file. But my main issue is why it displays the warning only on one computer and not the others (same QGIS project with same data)?
> Which mechanisms could trigger the difference in whether the warning should be shown or not?
> We are running QGIS 2.14.0 64 bit on Windows 7.
> Regards Casper
> -----Original Message-----
> From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Bernhard Ströbl
> Sent: 8. april 2016 10:38
> To: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Warning from DigitizingTools about CRS mismatch
> Hi Casper,
> DigitizingTools compares _only_ the SRS-id (SRS =
> SpatialReferenceSystem) of the project and the layer. If they missmatch the warning is thrown so the user gets a hint why certain functions are greyed out.
> Thus relevant is not the prj file but the SRS assigned to the layer and the project in their properties. To solve this issue: if they share a common projection, go in the layer properties and choose the same SRS as the project's from the list of projections.
> Background (AFAIK): In Shapefiles the data do not carry information on their SRS (like e.g. in PostGIS or gml). This information is contained in the (optional) prj file. QGIS reads the prj file and assigns the first matching SRS to the data (matching = definition is identical). If there is none matching, a USER-SRS is created with the projection information given in the prj file.
> Bernhard
> Am 08.04.2016 um 10:10 schrieb Casper Børgesen (CABO):
>> Hi!
>> I have a user who constantly get a yellow warning from QGIS when he enables editing on set of specific shape files. The message is:
>> DigitizingTools: Amend Line is disabled because layer CRS and project CRS do not match!
>> The project CRS is EPSG:25832. The shape file has the following .prj file:
>> PROJCS["ETRS_1989_UTM_Zone_32N",GEOGCS["GCS_ETRS_1989",DATUM["D_ETRS_1
>> 989",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",
>> 0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercato
>> r"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0
>> ],PARAMETER["Central_Meridian",9.0],PARAMETER["Scale_Factor",0.9996],P
>> ARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
>> In "layer properties/General/Coordinate reference system", QGIS displays "Selected CRS (EPSG: 3044, ETRS89 / ETRS-TM32".
>> If he enables editing on a shape file with the following .prj file, it doesn't happen:
>> PROJCS["ETRS89_UTM_zone_32N",GEOGCS["GCS_ETRS_1989",DATUM["D_ETRS_1989
>> ",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UN
>> IT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],P
>> ARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],PARAM
>> ETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETE
>> R["false_northing",0],UNIT["Meter",1]]
>> The strange thing is that this only happens on his computer not on a couple of other machines we have tried on.
>> If there indeed is a CRS mismatch it make sense, but he is the only of our users experiencing this.
>> Regards, Casper
__________ Information from ESET Mail Security, version of virus signature database 13303 (20160408) __________
The message was checked by ESET Mail Security.
http://www.eset.com
