[Qgis-developer] Using app MessageBar from providers ?
Even Rouault
even.rouault at spatialys.com
Sun Apr 10 06:12:21 PDT 2016
For the WFS provider, I'd like some messages, like a partial feature download,
to be emitted in a more prominent way than just in the message log. The
MessageBar would be appropriate for that, but from what I can see, it is not
currently possible for a provider to use it. A search in src/providers shows
that the same need was at least encountered once in the GRASS provider but the
code is commented out as the provider doesn't link against qgis_app.
So unless there's a good reason for a provider not to be able to use the
message bar, I was thinking to the following mechanism to implement it :
- QgsMessageLog would be extended to have 2 extra arguments bool
displayInMessagerBar = false, int duration = 0 in logMessage() /
messageReceived()
- QgisApp would connect on messageReceived() and when the boolean is set, it
would push the message to the main message bar.
Any thoughts ?
Even
http://www.spatialys.com
