[Qgis-developer] GRASS Plugin missing g.copy?
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Sun Apr 10 11:58:52 PDT 2016
I just tested the Browser in QGIS. It has indeed no "Copy" in the context menu, just "Rename", "Delete" or New vector layer.
However, Drag and Drop works fine. So if you want to copy a GRASS map, just drag it from the source to destination Mapset. Source and destination can be the same. If a map exists you are asked to specify a name...
Hence, g.copy is not present in the GRASS plugin in QGIS.
For me (QGIS 2.14.0, GRASS 7.0.3, OSGeo4W), g.copy starts also on the commandline. However, if you want to open the module GUI like that you have to run:
g.copy --ui
Cheers
Stefan
-----Original Message-----
From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of roy roy
Sent: 10. april 2016 16:11
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] GRASS Plugin missing g.copy?
Il 10/04/2016 15:57, Blumentrath, Stefan ha scritto:
> Maybe the browser provides that functionality... I guess it does...
> Cheers
> Stefan
It does not but this is not the problem, i notice that i cannot start g.copy from GRASS itself using the shell, so it's not a "GRASS Plugin" issue but more a GRASS GIS issue,
sorry and thaks anyway, roy
> ________________________________________
> Von: Qgis-developer [qgis-developer-bounces at lists.osgeo.org] im
> Auftrag von roy roy [royroge at outlook.com]
> Gesendet: Sonntag, 10. April 2016 13:06
> An: qgis-developer at lists.osgeo.org
> Betreff: [Qgis-developer] GRASS Plugin missing g.copy?
> It seems that g.copy is not avalilable in GRASS Plugin, QGIS 2.14.1 is
> this a "bug" or am i missing something?
> thanks, Roy.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
