[Qgis-developer] Warning from DigitizingTools about CRS mismatch
Casper Børgesen (CABO)
CABO at NIRAS.DK
Mon Apr 11 05:45:01 PDT 2016
Hi Bo
I tried the opposite of your suggestion and replaced my srs.db with the srs.db from the computer which displays the warning. I didn’t get any warnings, but I will try your suggestion when I get the chance.
The QGIS versions are the same, v. 2.14.0.
Regards, Casper
From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Bo Victor Thomsen
Sent: 9. april 2016 09:10
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Warning from DigitizingTools about CRS mismatch
Hi Casper -
AFAIK, All QGIS projection-definitions is stored in in a Sqlite database <qgis maindir>\apps\qgis\resources\srs.db
This database is initialized at the time of QGIS installation. This process might have been slightly different for the computers involved, so the different srs.db's have a sligthly different content (ex. different sort order or different content in some of the tables..)
You could try to copy the srs db from one the computers, that's working OK and overwrite the srs.db on the malfunctioning computer. I assume the QGIS version is the same for all the computer involved.
DISCLAIMER !
* This might not have any kind of influence!
* This might destroy your QGIS installation!
* You might be struck by lightning from the QGIS gods (or whatnot;-)
So use it with caution and have a backup of the original srs.db handy
Regards
Bo Victor Thomsen
GIS & Database specialist
Municipality of Frederikssund, Denmark
Den 08/04/16 kl. 13:27 skrev Casper Børgesen (CABO):
Hi Bernhard
I do follow your suggestions and they make perfectly sense. This is a warning and I can probably safely disregard it in this case. I'm more curious to discover why two computers using the same OS and QGIS version seems to handle the CRS difference differently. My initial mail was not specifically directed at DigitizingTools but it is (from the user point of view) the source of the warning.
What I suspect is that some setting somewhere, inside or outside QGIS, might lead QGIS to behave differently - and I am curious to know :)
Regards Casper
-----Original Message-----
From: Bernhard Ströbl [mailto:bernhard.stroebl at jena.de]
Sent: 8. april 2016 12:55
To: Casper Børgesen (CABO); qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>
Hi Casper,
I meant the CRS set in the layer's properties for the layer in question.
As you said both are using the same project so the project's CRS should be the same in both cases.
In your first mail you state that the project's CRS is EPSG:25832 and the layer's is EPSG:3044. There is the missmatch. Change this to
EPSG:25832 and all is fine. Check if the layer's CRS has been set to
EPSG:25832 on the working computer.
If the very same layer loads into the very same project with different CRS on different machines then this is a question of QGIS in general and has nothing to do with DigitizingTools (which is just pointing out the difference).
Bernhard
Am 08.04.2016 um 12:43 schrieb Casper Børgesen (CABO):
Hi Bernhard
Since its the same QGIS project were opening on the different computers, I would expect them to behave the same. The current CRS (as stated in the bottom right of the QGIS window) is EPSG:25832 (OTF).
I tried replacing the PRJ file of problematic shape file with the PRJ from the working shape file (see the first mail), but QGIS still displays the warning.
Regards, Casper
Sent: 8. april 2016 11:38
mismatch
Hi Casper,
no idea why they behave differently. Are the settings for the layer's SRS on both machines the same?
As I wrote, the warning is shown if there is a missmatch in the project's and the layer's SRS-id.
Bernhard
Am 08.04.2016 um 11:13 schrieb Casper Børgesen (CABO):
Hi Bernhard
Thanks for your answer.
Yes I know that QGIS tries hard to determine the SRS-id which matches the values of the PRJ file. But my main issue is why it displays the warning only on one computer and not the others (same QGIS project with same data)?
Which mechanisms could trigger the difference in whether the warning should be shown or not?
We are running QGIS 2.14.0 64 bit on Windows 7.
Regards Casper
On Behalf Of Bernhard Ströbl
Sent: 8. april 2016 10:38
To: qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>
mismatch
Hi Casper,
DigitizingTools compares _only_ the SRS-id (SRS =
SpatialReferenceSystem) of the project and the layer. If they missmatch the warning is thrown so the user gets a hint why certain functions are greyed out.
Thus relevant is not the prj file but the SRS assigned to the layer and the project in their properties. To solve this issue: if they share a common projection, go in the layer properties and choose the same SRS as the project's from the list of projections.
Background (AFAIK): In Shapefiles the data do not carry information on their SRS (like e.g. in PostGIS or gml). This information is contained in the (optional) prj file. QGIS reads the prj file and assigns the first matching SRS to the data (matching = definition is identical). If there is none matching, a USER-SRS is created with the projection information given in the prj file.
Bernhard
Am 08.04.2016 um 10:10 schrieb Casper Børgesen (CABO):
Hi!
I have a user who constantly get a yellow warning from QGIS when he enables editing on set of specific shape files. The message is:
DigitizingTools: Amend Line is disabled because layer CRS and project CRS do not match!
The project CRS is EPSG:25832. The shape file has the following .prj file:
PROJCS["ETRS_1989_UTM_Zone_32N",GEOGCS["GCS_ETRS_1989",DATUM["D_ETRS
_
1
989",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich"
0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Merca
t
o
r"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.
0
],PARAMETER["Central_Meridian",9.0],PARAMETER["Scale_Factor",0.9996]
, P ARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
In "layer properties/General/Coordinate reference system", QGIS displays "Selected CRS (EPSG: 3044, ETRS89 / ETRS-TM32".
If he enables editing on a shape file with the following .prj file, it doesn't happen:
PROJCS["ETRS89_UTM_zone_32N",GEOGCS["GCS_ETRS_1989",DATUM["D_ETRS_19
8
9
",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],
U
N
IT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"]
P
ARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],PAR
A
M
ETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAME
T E R["false_northing",0],UNIT["Meter",1]]
The strange thing is that this only happens on his computer not on a couple of other machines we have tried on.
If there indeed is a CRS mismatch it make sense, but he is the only of our users experiencing this.
Regards, Casper
__________ Information from ESET Mail Security, version of virus
signature database 13303 (20160408) __________
The message was checked by ESET Mail Security.
http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 13303 (20160408) __________
http://www.eset.com
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160411/61ccc55f/attachment-0001.html>
