[Qgis-developer] PyQt limitations of QGIS sip bindings... is there a workaround?
Luigi Pirelli luipir at gmail.com
Fri Apr 15 03:19:23 PDT 2016
solved using mock module and mocked classes in qgis.testing
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 13 April 2016 at 13:08, Luigi Pirelli <luipir at gmail.com> wrote:
> Hi
> I've this problem, I want to know the number of listeners connected to a signal.
> In c++ this is possibile using QObject.receivers method.
> this seems not possibile for c++ binded object to python... or I can't
> find how to do.
> for example in python console
> iface.receivers(SIGNAL("initializationCompleted"))
> Traceback (most recent call last):
>   File "<input>", line 1, in <module>
> RuntimeError: no access to protected functions or signals for objects
> not created from Python
> and the error comes from:
> https://github.com/ifwe/sip/blob/master/siplib/siplib.c#L5717
> there is some workaround to this limitation?
> the reason of this check is to write tests that can check if a method
> register a slot to a specific signal.
> Luigi Pirelli
> * Mastering QGIS:
