[Qgis-developer] Troubles with label alignement
Denis Rouzaud denis.rouzaud at gmail.com
Tue Apr 19 23:54:20 PDT 2016
Hi all,
I noticed some problems with label alignement.
I have a symbol in map units (a circle), within which I place a label
with font size in map units too.
It used to be centered in the circle, it is not anymore with QGIS master
81744ec.
See attached image.
I checked the label properties everything is fine (alignment: center,
placement: center quadrant), same for symbol (anchor point: center).
Does this speak to anyone?
Do you have an idea which change broke this?
Thanks a lot for your help,
Denis
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160420/fbe202aa/attachment.png>
