[Qgis-developer] Different GeoJson results from QgsVectorFileWriter.writeAsVectorFormat() on different systems
Jürgen E. Fischer
jef at norbit.de
Wed Apr 20 09:17:41 PDT 2016
Hi Alex,
On Wed, 20. Apr 2016 at 09:05:05 -0700, Alex Mandel wrote:
> > Answer is there :-)
> > https://github.com/qgis/QGIS/blob/master/src/core/qgsvectorfilewriter.cpp#L364
> Ah so you're saying it's the GDAL version, Windows being 2.0+ and Linux
> being likely 1.11.x?
2.8 didn't have support for writing OFTInteger64 (was added in master 7de0757).
So there it's always OFTString regardless of the GDAL version. Only in master
it different depending on the GDAL version.
Jürgen
PS: except if the source file is also read by OGR and different GDAL versions
consider the type of the input field differently.
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160420/51f3a817/attachment.sig>
