[Qgis-developer] Questions about QgsEditorWidgetWrapper value() / setValue()
Even Rouault
even.rouault at spatialys.com
Fri Apr 22 05:38:43 PDT 2016
I'm trying to understand the abstraction of QgsEditorWidgetWrapper.
1) Semantics question
Am I right that there's no guarantee (and that's actually intended) that the
following pseudo-code is true :
setValue(v)
assert value() == v
For example in the QgsValueRelationWidgetWrapper(), value() returns the value
of the value column of the referenced layer, which corresponds to the key
provided to setValue().
And that's value() that is used when displaying the attribute table in table
view mode.
So this value() method is more a displayValue(), right ? And setValue() would
be setRawValue() / setSourceValue() ?
2) Implementation of QgsRelationReferenceWidgetWrapper.
The value() method in that case actually returns the foreign key set by
setValue(). Is that intended ? To have similar behaviour as
QgsValueRelationWidgetWrapper, one could rather expect value() to return the
evaluation of the display expression, no ?
If the current behaviour is intended, is there something in the abstraction of
QgsEditorWidgetWrapper that could return the evaluation of the display
expression for a QgsRelationReferenceWidgetWrapper ?
Thanks
Even
http://www.spatialys.com
