[Qgis-developer] [Server] performance questions
Jörg Habenicht
jh at mwerk.net
Fri Apr 22 06:20:47 PDT 2016
Hi Andreas, dear list,
sorry for the warm up of this old topic.
There is in deed a need to enable multi threading in Qgis-Server.
In our company we use around 60 different layer to lay some topics on
the map. This may be an extreme example to read, but quite common in our
environment, i.e. we can not lower this number significantly.
A warmed up QGis-Server process which already read and cached the
Configuration file qgis-xy.conf still needs around 20 seconds to
calculate the complete resulting map picture.
During this calculation there is only one thread working, serializing
the DB-requests, calculation the layer picture and mapping the picture
on the resulting picture.
The process is running on a multi core server. If we can utilize the
idle cores to do useful work, this can be an easy example to speed up
the process (significant).
I'd like to share my developing experience to do this change, but I
would need further information and some support to do some useful patches.
I have scanned the git-Qgis sources (commit
81744ecf90a8f6c1e2e94fdacb07e3dca6987dcc) for a suitable multithreading
entry. Found QgsMapRenderer::render() because of the line "while (
li.hasPrevious() )". It seems in this loop the layers are painted in
serial onto the resulting picture.
If I can build an auto parallel computing with QtConcurrent in this
place there seems to be the most gain. I mean to parallelize the loop
with concurrent DB requests, concurrent painting in separate pictures
and in serial map the single pictures onto the result picture.
Right now I don't know if I can do DB requests in parallel, or where the
code for database requests is buried.
And how about the calls inside the loop, are there side effects
preventing multi threading?
Do you got hints, flames or suggestions?
cu
Jörg
Am 23.02.2016 um 16:39 schrieb Neumann, Andreas:
> Hi Régis,
> QGIS server is single-threaded. You can't simply turn on multi-threaded
> rendering in QGIS server. The other issue is that each Apache FCGI
> process has it's own set of cache. So if you have 5-10 parallel Apache
> threads or processes each thread/process has it's own cache. If your
> client hits a thread that has the cache unititialized you will have wait
> longer until this cache is fillled.
> I once asked Marco whether one could
> a) have a shared cache for all Apache threads or processes
There is no shared cache, because Apache spawns QGis-Processes with its
own memory layout. these Processes know nothing about its neighbor, and
you have a hard time to exchange data between all processes.
How about a scheduler, which assigns requests to warmed up Qgis-processes?
> b) support multi-threaded rendering
> But he said it would be very complicated to implement a) and b), if not
> impossible. Maybe other devs have other views. Note that was about 2
> years ago, when I last discussed this with Marco.
> Nevertheless I believe there would be room for performance improvements
> in QGIS server - if interested parties share their efforts (be it dev
> time or financial resources).
[snip]
> Andreas
[snip]
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
mWerk GmbH
Dipl.-Ing. Jörg Habenicht
Landwehrstr. 76
30519 Hannover
(T) +49 511 9999 8033
(F) +49 511 9999 8041
(E) jh at mwerk.net
Amtsgericht Hannover HRB 206522
Geschäftsführer
Reiner Brachvogel
Dennis Kornehl
