[Qgis-developer] qgis-bin crashes accessing relations
Mihai Terente
terenteml at gmail.com
Tue Apr 26 08:00:31 PDT 2016
Dear fellows,
My QGIS, on Windows 7, is crashing when I'm trying to access a relation
within a field form layout built with drag-and-drop designer.
I don't know if my particular use case is doing this, so I briefly
report it here:
I have 5 Postgis tables (Appartment, Building, Land, Registration and
Deed) related like this:
Apartment --- many-to-one ---> Building --- many-to-one ---> Land
Registration --- many-to-one ---> Deed
Registration --- many-to-one ---> Land
Registration --- many-to-one ---> Building
Registration --- many-to-one ---> Apartment
With all the relations being set accordingly in QGIS, I end up having
the Registrations list within Land, Building, Apartment and Deed field
forms (each with a tab, for convenience).
I began adding the relations and testing in the above order, starting
with Registration - Deed. Everything was fine, until I added the last
relation.
This point forward, QGIS crashes when I try to access the tab were the
Registration relation fields are lying, no matter which table I'm in.
The dump summary extracted from the dump file with VS is:
Dump Summary
Dump File: qgis-20160426-164946-6580-7048-ea85bef.dmp :
C:\Users\mihai.terente\AppData\Local\Temp\qgis-20160426-164946-6580-7048-ea85bef.dmp
Last Write Time: 26.04.2016 16:50:14
Process Name: qgis-bin.exe : C:\OSGeo4W64\bin\qgis-bin.exe
Process Architecture: x64
Exception Code: 0xC0000005
Exception Information: The thread tried to read from or write to a
virtual address for which it does not have the appropriate access.
Heap Information: Not Present
The funny thing is that I am able to reproduce the use case in a fresh
project, but my initial .qgs is highly customized and I would be glad to
prevent this from happening in production so any hint on this is highly
appreciated.
All the best,
Mihai Terente
