[Qgis-developer] Unable to build QGIS-Website with Paver
Richard Duivenvoorde
rdmailings at duif.net
Wed Apr 27 07:56:22 PDT 2016
Googling I found this
https://github.com/pypa/virtualenv/issues/72
and there they say:
In case someone else is looking at this, make sure "C:\[PythonDir]\DLLs"
is in your pythonpath environment variable, NOT your path variable.
In your case maybe the problem is maybe two python installs? One normal
one and one in osgeo4w?
Another option would be to try the 'Docker'-way.
I just build both docs and website (and translations) on a Windows 10
machine, following the instructions from:
https://github.com/qgis/QGIS-Website#building-the-website-using-docker
Only change is that boot2docker is not 'depricated', and you should use
this docker-product:
https://www.docker.com/products/docker-toolbox
let me know if you need further help.
Regards,
Richard
On 20-04-16 20:25, DelazJ wrote:
> Hi,
> I'm tring to build QGIS-website with Paver
> <https://github.com/qgis/QGIS-Website#building-the-website-using-paver>
> on Windows 10 and it fails in the earlier steps
> I have easy_install installed (can find it in my
> osgeo4w64/Apps/Python/Scripts folder, added to the PATH)
> When I launch python bootstrap.py from my local repo folder, I get :
> F:\SIG\GitHub\QGIS-Website> python bootstrap.py
> PYTHONHOME is set. You *must* activate the virtualenv before using it
> New python executable in virtualenv\Scripts\python.exe
> Installing setuptools..............
> Complete output from command
> F:\SIG\GitHub\QGIS-W...v\Scripts\python.exe -c "#!python
> \"\"\"Bootstra...sys.argv[1:])
> " --always-copy -U setuptools:
> Traceback (most recent call last):
> File "<string>", line 278, in <module>
> File "<string>", line 210, in main
> File "<string>", line 132, in download_setuptools
> File "C:\OSGeo4W64\apps\Python27\Lib\urllib2.py", line 94, in <module>
> import httplib
> File "C:\OSGeo4W64\apps\Python27\Lib\httplib.py", line 71, in <module>
> import socket
> File "C:\OSGeo4W64\apps\Python27\Lib\socket.py", line 47, in <module>
> import _socket
> ImportError: No module named _socket
> ...Installing setuptools...done.
> File "bootstrap.py", line 2601, in <module>
> main()
> File "bootstrap.py", line 981, in main
> no_pip=options.no_pip)
> File "bootstrap.py", line 1093, in create_environment
> search_dirs=search_dirs, never_download=never_download)
> File "bootstrap.py", line 613, in install_setuptools
> File "bootstrap.py", line 585, in _install_req
> cwd=cwd)
> File "bootstrap.py", line 1059, in call_subprocess
> % (cmd_desc, proc.returncode))
> OSError: Command F:\SIG\GitHub\QGIS-W...v\Scripts\python.exe -c "#!python
> " --always-copy -U setuptools failed with error code 1
> Can someone explain what's wrong, please?
> Thanks,
> H.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
