[Qgis-developer] Cleaning up the QEP list
Neumann, Andreas
a.neumann at carto.net
Mon Aug 1 22:56:36 PDT 2016
Hi Nathan,
no problem. Just wanted to send you some input. Hopefully it helps. You
are doing a lot for the project and I understand that during 2.16 you
were focused on the styling dock.
As always: thanks for your efforts!
Andreas
On 2016-08-01 01:26, Nathan Woodrow wrote:
> Hey Andreas,
> Thanks for raising it as a issue. I will have a look this week and do some clean up. I think I will make some more labels to show better status.
> Sorry for the lack of focus on them.
> Regards,
> Nathan
> On Mon, Jul 25, 2016 at 7:17 PM, Neumann, Andreas <a.neumann at carto.net> wrote:
>> Hi all, Hi Nathan,
>> I am looking at the QEPs from time to time that and I think it needs a little attention. Quite a few proposals would be ready to make a decision. Some QEPs are ready but lack funding. Perhaps we can introduce a new label stating "Needs funds" or something similar? It would help potential funders to pick things they like to see implemented. Quite a few of the proposals are already implemented, sometimes even if they don't have the "Accepted label" - i guess some of the implementations had time pressure due to the 2.16 list and thus couldn't wait for voting/acceptance.
>> Devs want to start working on many of the issues mentioned in the QEPs - so decisions need to be taken in a timely manner.
>> Here are some of my personal suggestions for changes / closings:
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/42 (Compulsory Unit Tests for Core Changes) - discussion stalled - but I think now would be the perfect timing to implement this proposal.
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/40 (Geometry redesign) - was implemented already 2 or 3 versions ago - should be accepted and closed
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/59 (aggregate functions) is accepted, implemented - it can be closed
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/58 (QGIS Styles, Symbols ans SVG Markers Sharing Repository) - is currently being implemented by Akbar - shouldn't it be voted on/accepted?
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/53 (WFS provider enhancements) - is already implemented and should be closed
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/49 (Label mask) - would be ready to implement, but lacks funding (add the new "Needs funds" label?)
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/46 (Labling path) - would be ready to implement, but lacks funding (add the new "Needs funds" label?)
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/45 (Long term releases) - implemented - should be closed
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/43 (Rename Compositions to Print Layouts) - would be good to be addressed during work for 3.x - can we continue discussion and vote on it?
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/39 (Layout rework (composer v2)) - Nyall wants to start on this - so it should be discussed and accepted
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/38 (Inheritable property collections) - unsure about the status here, apparently it has a prototype implementation. How does this relate to the variable system introduced recently?
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/37 (Fields and Forms Redesign) - would be a good candidate to be implemented during QGIS 3.x - probably lacks funding
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/35 (Authentication configuration system with master password) - already implemented. Should be accetped and closed.
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/32 (Add QGIS server access control interface for python plugins) - already implemented. Should be accepted and closed:
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/31 (QGIS Legal Entity) - accepted by Loomio vote and mostly implemented. Should be acepted and closed.
>> - https://github.com/qgis/QGIS-Enhancement-Proposals/issues/29 (QGIS 3.0) - discussion maybe a bit outdated? Close?
>> It would be good, if we, as the project would take the QEPs a bit more seriously and maintain them accordingly. Seems like some devs do, some don't. Any comments?
>> Thanks and greetings,
>> Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160802/e627b80c/attachment.html>
