[Qgis-developer] Strange output from dxf2shp plugin
Alexandre Neto senhor.neto at gmail.com
Thu Aug 11 09:41:41 PDT 2016
While trying to convert a DXF file using the dxf2shp plugin, I'm getting a
strange .shp.shp file instead of the name I have chosen. This makes it very
useless as QGIS can not recognise it as a valid vector layer later.
But, if I overwrite an existing file, it saves just fine.
This is happening to me in 2.14 and 2.16.
Is there any workaround?
What are the remaining advantages of using this instead of loading the
dxf file using add vector layer?
Alexandre Neto
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160811/2db4046a/attachment.html>
