[Qgis-developer] ubuntu 2.16.1 packages still core dump
Marco Bernasocchi marco at opengis.ch
Mon Aug 15 22:46:52 PDT 2016
Hi guys, any idea on this? it is still the same problem of
https://lists.osgeo.org/pipermail/qgis-developer/2016-July/043744.html
I removed all packaged qgis stuff, and installed all the 2.16.1
packages, same result.
I'm on ubuntu xenial with http://qgis.org/debian xenial in apr sources
self compilation has no issues.
ciao
Marco
marco at placebo:~$ gdb qgis.bin
GNU gdb (Ubuntu 7.11.1-0ubuntu1~16.04) 7.11.1
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from qgis.bin...(no debugging symbols found)...done.
(gdb) r
Starting program: /usr/bin/qgis.bin
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fffd5103700 (LWP 13538)]
[New Thread 0x7fffd4902700 (LWP 13539)]
[New Thread 0x7fffcf8be700 (LWP 13540)]
[New Thread 0x7fffcc9ef700 (LWP 13541)]
[New Thread 0x7fffbffff700 (LWP 13543)]
Warning: loading of qgis translation failed
[/usr/share/qgis/i18n//qgis_en_US]
Warning: loading of qt translation failed
[/usr/share/qt4/translations/qt_en_US]
[Thread 0x7fffcc9ef700 (LWP 13541) exited]
[New Thread 0x7fffcc9ef700 (LWP 13546)]
[New Thread 0x7fffb60a5700 (LWP 13547)]
[New Thread 0x7fffb521c700 (LWP 13548)]
[New Thread 0x7fffb4a1b700 (LWP 13549)]
[New Thread 0x7fffa7df8700 (LWP 13550)]
Warning: QCss::Parser - Failed to load file  "/style.qss"
[New Thread 0x7fffa75f7700 (LWP 13552)]
Warning: QLayout: Attempting to add QLayout "" to QgsPanelWidgetStack
"mWidgetStack", which already has a layout
Warning: QVariantMap DBusMenuExporterDBus::getProperties(int, const
QStringList&) const: Condition failed: action
[New Thread 0x7fff8965c700 (LWP 13557)]
Warning: void DBusMenuExporterPrivate::addAction(QAction*, int): Already
tracking action "&Toolbox" under id 281
[New Thread 0x7fff7c9b3700 (LWP 13568)]
Warning: Object::connect: No such signal QWebPage::loadProgress(int)
QWebPage::unsupportedContent(QNetworkReply*)
Warning: Object::connect: No such signal QWebFrame::titleChanged(QString)
Warning: Object::connect: No such signal QWebFrame::iconChanged()
Warning: Object::connect: No such signal QWebFrame::urlChanged(QUrl)
Warning: Object::connect: No such signal QWebPage::loadStarted()
Warning: Object::connect: No such signal QWebPage::loadFinished(bool)
Warning: Object::connect: No such signal QWebPage::statusBarMessage(QString)
Warning: Object::connect: No such signal QWebPage::linkClicked(QUrl)
Warning: Object::connect: No such signal QWebPage::selectionChanged()
Warning: Object::connect: No such signal QWebPage::microFocusChanged()
[New Thread 0x7fff3b9bd700 (LWP 13569)]
Warning: QMetaObject::invokeMethod: No such method
QWebPage::repaintRequested(QRect)
Thread 1 "qgis.bin" received signal SIGSEGV, Segmentation fault.
0x00007ffff5b36265 in QString::remove(QChar, Qt::CaseSensitivity) ()
from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
(gdb) bt
#0  0x00007ffff5b36265 in QString::remove(QChar, Qt::CaseSensitivity) ()
#1  0x00007fff916d88d2 in ?? () from
/usr/lib/x86_64-linux-gnu/libQtWebKit.so.4
#2  0x00007fff91cd9789 in ?? () from
#3  0x00007fff91cd98f4 in ?? () from
#4  0x00007fff91d13205 in ?? () from
#5  0x00007fff91d1059d in ?? () from
#6  0x00007fff91cf78b6 in ?? () from
#7  0x00007fff91cf698f in ?? () from
#8  0x00007fff91cc9615 in ?? () from
#9  0x00007fff91ce35b8 in ?? () from
#10 0x00007fff91ce362e in ?? () from
#11 0x00007fff91cfec28 in ?? () from
#12 0x00007fff91d063f3 in ?? () from
#13 0x00007fff916e3cb1 in ?? () from
#14 0x00007fff91d04d71 in ?? () from
#15 0x00007fff91ce475d in ?? () from
#16 0x00007fff91ce49ac in ?? () from
#17 0x00007fff91ce51b1 in ?? () from
#18 0x00007fff916942e5 in QWebFrame::load(QNetworkRequest const&,
QNetworkAccessManager::Operation, QByteArray const&) () from
#19 0x00007fff9169536b in QWebFrame::load(QUrl const&) () from
#20 0x00007fff9169551b in QWebFrame::setUrl(QUrl const&) () from
---Type <return> to continue, or q <return> to quit---
#21 0x00007fff937c17e5 in ?? () from
/usr/lib/python2.7/dist-packages/PyQt4/QtWebKit.so
#22 0x00007fff9d4f6751 in PyEval_EvalFrameEx () from
/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#23 0x00007fff9d4f4e24 in PyEval_EvalFrameEx () from
#24 0x00007fff9d61f01c in PyEval_EvalCodeEx () from
#25 0x00007fff9d5752e0 in ?? () from
#26 0x00007fff9d5481e3 in PyObject_Call () from
#27 0x00007fff9d5bc31c in ?? () from
#28 0x00007fff9d5481e3 in PyObject_Call () from
#29 0x00007fff9d5690bd in ?? () from
#30 0x00007fff9d4ff16f in ?? () from
#31 0x00007fff9d5481e3 in PyObject_Call () from
#32 0x00007fff9d4f313c in PyEval_EvalFrameEx () from
#33 0x00007fff9d61f01c in PyEval_EvalCodeEx () from
#34 0x00007fff9d5752e0 in ?? () from
#35 0x00007fff9d5481e3 in PyObject_Call () from
#36 0x00007fff9d5bc31c in ?? () from
#37 0x00007fff9d5481e3 in PyObject_Call () from
#38 0x00007fff9d61e447 in PyEval_CallObjectWithKeywords () from
#39 0x00007fff9d5ca2dc in PyInstance_New () from
#40 0x00007fff9d5481e3 in PyObject_Call () from
#41 0x00007fff9d4f313c in PyEval_EvalFrameEx () from
#42 0x00007fff9d4f4e24 in PyEval_EvalFrameEx () from
#43 0x00007fff9d61f01c in PyEval_EvalCodeEx () from
#44 0x00007fff9d4f4cfd in PyEval_EvalFrameEx () from
#45 0x00007fff9d61f01c in PyEval_EvalCodeEx () from
#46 0x00007fff9d4f4cfd in PyEval_EvalFrameEx () from
#47 0x00007fff9d61f01c in PyEval_EvalCodeEx () from
#48 0x00007fff9d5752e0 in ?? () from
#49 0x00007fff9d5481e3 in PyObject_Call () from
#50 0x00007fff9d5bc31c in ?? () from
#51 0x00007fff9d5481e3 in PyObject_Call () from
#52 0x00007fff9d5690bd in ?? () from
#53 0x00007fff9d4ff16f in ?? () from
#54 0x00007fff9d5481e3 in PyObject_Call () from
#55 0x00007fff9d4f313c in PyEval_EvalFrameEx () from
#56 0x00007fff9d4f4e24 in PyEval_EvalFrameEx () from
#57 0x00007fff9d61f01c in PyEval_EvalCodeEx () from
#58 0x00007fff9d4edb89 in PyEval_EvalCode () from
#59 0x00007fff9d55b166 in PyRun_StringFlags () from
#60 0x00007fff9d9c7c1d in ?? () from /usr/lib/libqgispython.so.2.16.1
#61 0x00007fff9d9ce6e6 in ?? () from /usr/lib/libqgispython.so.2.16.1
#62 0x00007ffff762d66b in ?? () from /usr/lib/libqgis_app.so.2.16.1
#63 0x00007ffff648d13c in QgsPythonRunner::run(QString const&, QString
const&) () from /usr/lib/libqgis_core.so.2.16.1
#64 0x00007ffff7621e87 in QgisApp::QgisApp(QSplashScreen*, bool, bool,
QWidget*, QFlags<Qt::WindowType>) () from /usr/lib/libqgis_app.so.2.16.1
#65 0x0000555555559ce8 in ?? ()
#66 0x00007ffff4435830 in __libc_start_main (main=0x555555558ae0,
argc=1, argv=0x7fffffffddf8, init=<optimized out>, fini=<optimized out>,
rtld_fini=<optimized out>, stack_end=0x7fffffffdde8) at
../csu/libc-start.c:291
#67 0x000055555555e7a9 in _start ()
(gdb)
Marco Bernasocchi
OPENGIS.ch - berna.io - 27summits.ch
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160816/d9a5179e/attachment.sig>
