[Qgis-developer] Fwd: [SoC] GSoC GDAL DWG Support [Week 12 report, final]
Neumann, Andreas
a.neumann at carto.net
Tue Aug 16 23:52:42 PDT 2016
Hi Paolo,
I'll let Jürgen comment in more detail.
But their approach is different to the libdxfrw approach. Also - again
the main bottleneck would be the limited OGR features styles. Also, the
approach Jürgen will do will generate label/symbology rules as good as
possible and provide caching in a SpatiaLite or geopackage file behind
the scenes.
But it is good to have choice. If we can enable this in our "Add Vector
Layer" dialog as well, people could then decide whether they want the
OGR DXF/DWG driver or the QGIS native one through libdxfrw.
Greetings,
Andreas
On 2016-08-17 08:32, Paolo Cavallini wrote:
> Hi all,
> does this have any impact on our developmant?
> All the best.
> -------- Messaggio Inoltrato --------
> *Week 12 Report [Final] blogpost link
> <http://gsoc2016gdaldwg.blogspot.ru/2016/08/week-12-report-final.html>*
> Brief description of the idea.
> The aim of my project was to extend GDAL supported formats with DWG.
> The state of the project as it was BEFORE your GSOC.
> There was a DWG support, but it was not built-in by default, and GDAL
> Driver was based on third-party library Teigha (which is not X/MIT
> licensed, not even close).
> The addition that your project brought to the software.
> Libopencad (GDAL CAD Driver engine)
> Overview
> Libopencad is a library written in C++11, which provides a way to
> read/write CAD (DWG/DXF/DXFB) files. It was designed to have a uniformal
> API to work with any CAD files. It has a base class - CADFile.
> Inheriting this class it's possible to create a 'driver' for any CAD
> format, all you need to do - is to overwrite interface functions like
> 'GetGeometry(index)', and others. Now it has an implementation for
> DWG2000 (R15), but only for read.
> Library comes with 'cadinfo' utility, which prints out everything
> library can get from file - header variables, CAD custom classes,
> presented layers and geometries with their attributes.
> Internal structure
> Library presents CAD objects in different ways - base class CADObject
> and other CAD...Object classes are exact analogues of how DWG format
> stores information about its objects. CADGeometry, and other classes
> which inherits it, are done for API access to CAD...Object classes.
> Library supports 3 modes of reading - READ_ALL (means everything which
> can be extracted from CAD file will be read) READ_FAST (skipping some
> kind of meanless information - linetypes, CRC check, etc), READ_FASTEST
> (only geometries reading, additional info is skipped).
> When parsing the file, library does not store any information it does
> not need. First, it reads file meta-information, and creates a file map.
> It only stores some info about presented layers, and header variables.
> Then, when calling application uses CADLayer.GetGeometry(index), it
> actually reads a geometry from file, using prepared file map. Sometimes
> it will be slower than having everything you have read in cache, but
> gives you more flexibility what you want to store in memory, and what
> you wont.
> Library also has special classes which incapsulates I/O functions, so
> it's possible to reimplement them for your needs - by default it uses
> std::fstream, but you can make it possible to work with network by make
> a class inherited from CADFileIO.
> Supported geometries list:
> Point, Circle, Ellipse, Arc, Text, Solid, Spline, Line, Polyline 2D,
> Polyline 3D, LWPolyline, Ray, Raster (Images), MText, MLine, XLine,
> Polyface Mesh, 3DFace.
> GDAL CAD Driver
> Overview
> GDAL CAD Driver uses libopencad as a datasource. Not everything that
> libopencad can read from file is mapped into OGR infrastructure, but it
> will be done in near future. Current features are:
> 1.
> OpenOptions are presented with 2 options:
> - MODE - READ_ALL/READ_FAST/READ_FASTEST (means the same as library
> OpenOptions).
> - ADD_UNSUPPORTED_GEOMETRIES_DATA (YES/NO) - unstable feature, if some
> of the objects cannot be mapped into OGR representation (or its just not
> implemented yet), it will be presented as a CADUnknown object -
> OGRFeature without geometric representation, but with basic info -
> geometry type, some additional params.
> 2.
> CAD header variables are mapped into metadata.
> 3.
> Unlike DXF driver, CAD driver stores vector data in the appropriate
> layers (not all entities in single layer).
> 4.
> Raster subdatasets are also supported.
> 5.
> Coordinate system is extracted from DWG file (if it is presented in
> accordance with ESRI Docs for DWG files), or from %FILENAME%.prj
> file in the same directory.
> 6.
> CAD Geometry attributes mapping is completely done into
> OGRLayerDefn. So, any ACAD BlockReference attributes will be seen in
> OGRLayerDefn.
> Add all the links (hopefully permanent) to access the relevant code and
> documentation for the user to get started with testing your application.
> During the planning stage, I decided to separate my project into 2
> parts: separated CAD formats support library (named libopencad), and
> GDAL driver, which uses it. Library can be used by itself for any
> reason, and will be maintained after GSoC.
> Links:
> Libopencad repository
> <https://github.com/sandyre/libopencad>(installation is described in
> REAME.MD)
> Libopencad + GDAL fork <https://github.com/sandyre/gdal_libopencad>
> Blog with all reports and notices <http://gsoc2016gdaldwg.blogspot.ru/>
> PR with my work into GDAL-trunk. <https://github.com/OSGeo/gdal/pull/145>
> GDAL Wiki driver page <https://trac.osgeo.org/gdal/wiki/DWG_driver>
> A slide / image should serve to show the main elements of your project.
> Raster and vector layers by the same driver (left - ArcGIS, right -
> QGIS): image link <https://pbs.twimg.com/media/Cm2N_-nVIAA8jBn.jpg>
> A little comparison between original data source (ACAD) and QGIS with
> new DWG driver: image link <https://pbs.twimg.com/media/CmwXIBnWcAAz22X.jpg>
> Blockreference attributes mapping into OGRLayerDef: image link
> <https://pbs.twimg.com/media/CocvxggWYAACiIg.jpg>
> Best regards,
> Alexandr Borzykh
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160817/cce0383a/attachment-0001.html>
