[Qgis-developer] Is any work being done on problems with Qlonglong fields?
Matthias Kuhn
matthias at opengis.ch
Mon Aug 22 04:55:53 PDT 2016
Hi Morten,
This is something that needs to be solved in the many plugins
themselves, so it would be best to start opening issues there.
Regards
Matthias
On 08/22/2016 01:44 PM, magerlin wrote:
> At least in Win7 64 bit many plugins either ignore Qlonglong fields or regard
> them as text.
> It is quite annoying to have to store attributes as Real to be able to work
> in Qgis - especially since you have to add decimals as real 10.0
> automatically is being converted to Qlonglong. And if you create a field as
> short integer next time you open the shape file it is being regarded as
> Qlonglong.
> Post in Qgis User
> <http://osgeo-org.1560.x6.nabble.com/Many-problems-with-qlonglong-Integer64-fields-td5264507.html>
> I am unfortunately not a programmer so I cannot participate in solving
> this....
> Regards Morten
> Currently using Qgis 2.16.1 (OSGeo4),
> Windows 7, 64bit
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Is-any-work-being-done-on-problems-with-Qlonglong-fields-tp5281463.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160822/0a7fa8f6/attachment.sig>
