[Qgis-developer] QGIS 2.16 compiling with '-std=c++11', Screen refreshing
Mark Johnson mj10777 at googlemail.com
Sun Aug 28 21:46:04 PDT 2016
Yesterday I managed to resolve dependency problems which prevented the
install of the present QGIS 2.16.
So I am now attempting to compile the branch 'release-2_16', since 2.10 was
the last version that I could compile and use properly.
At 51% it received warnings/errors:
"warning: identifier 'nullptr' is a keyword in C++11 [-Wc++0x-compat]"
"error: 'nullptr' was not declared in this scope"
which I hope will be resolved by adding '-std=c++11' to the CMAKE_CXX_FLAGS
I just greped the source and see that 'nullptr' is used quite often and has
been  defined in
- analysis/qgsrastercalcparser.cpp
- core/qgsexpressionparser.cpp
since version 2.8, so I am not sure if this is the correct solution
(compiling now at 48%)
While trying out 2.16, I noticed that the Screen refreshing (since commit
2014_05_01) still blanks out the screen when moving around.
This is VERY hard on the eyes and is the main reason why I have been using
the commit of 2014_02_22 since then.
But since there have been many changes since the (geometry editing is what
interests me most), I would like to use the latest version - but without
this eye-sore (including the distracting scrollbar that goes back and forth
instead of a 'busy' cursor).
Is there a way to turn is off?
- i.e. back to previous 'freeze' of the image with 'busy' cursor until the
refresh has completed
I do a lot of georeferencing, so am concentrating on the map while moving,
so this 'blinking' is truly a strain on the eyes.
The above solution seems to have resolved the first issue, since it went on
to 54% where it failed while linking qgis.
(Undefined reference
to `QgsRelationManagerDialog::setLayers(QList<QgsVectorLayer*> const&)')
Mark Johnson, Berlin Germany
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160829/9801e1d5/attachment-0001.html>
