[Qgis-developer] QEP about Multimap support for QGIS
A Huarte
ahuarte47 at yahoo.es
Mon Aug 29 02:45:23 PDT 2016
Hi, there is not problem with this. Simply I did the minor work as possible :-)
Yes, we could show a new item menu with all canvas currently created and then the user define which of them to synchronize.
De: Casper Børgesen (CABO) <CABO at NIRAS.DK>
Para: A Huarte <ahuarte47 at yahoo.es>
CC: QGIS Developer Mailing List <Qgis-developer at lists.osgeo.org>
Enviado: Lunes 29 de agosto de 2016 11:38
Asunto: RE: [Qgis-developer] QEP about Multimap support for QGIS
#yiv9524372747 #yiv9524372747 -- _filtered #yiv9524372747 {font-family:Helvetica;panose-1:2 11 6 4 2 2 2 2 2 4;} _filtered #yiv9524372747 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #yiv9524372747 {panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv9524372747 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv9524372747 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #yiv9524372747 {font-family:Georgia;panose-1:2 4 5 2 5 4 5 2 3 3;}#yiv9524372747 #yiv9524372747 p.yiv9524372747MsoNormal, #yiv9524372747 li.yiv9524372747MsoNormal, #yiv9524372747 div.yiv9524372747MsoNormal {margin:0cm;margin-bottom:.0001pt;font-size:12.0pt;}#yiv9524372747 a:link, #yiv9524372747 span.yiv9524372747MsoHyperlink {color:blue;text-decoration:underline;}#yiv9524372747 a:visited, #yiv9524372747 span.yiv9524372747MsoHyperlinkFollowed {color:purple;text-decoration:underline;}#yiv9524372747 p.yiv9524372747MsoAcetate, #yiv9524372747 li.yiv9524372747MsoAcetate, #yiv9524372747 div.yiv9524372747MsoAcetate {margin:0cm;margin-bottom:.0001pt;font-size:8.0pt;}#yiv9524372747 span {}#yiv9524372747 span.yiv9524372747apple-converted-space {}#yiv9524372747 span.yiv9524372747EmailStyle19 {color:#1F497D;}#yiv9524372747 span.yiv9524372747BalloonTextChar {}#yiv9524372747 .yiv9524372747MsoChpDefault {font-size:10.0pt;} _filtered #yiv9524372747 {margin:3.0cm 2.0cm 3.0cm 2.0cm;}#yiv9524372747 div.yiv9524372747WordSection1 {}#yiv9524372747 _filtered #yiv9524372747 {} _filtered #yiv9524372747 {font-family:Symbol;} _filtered #yiv9524372747 {} _filtered #yiv9524372747 {font-family:Wingdings;} _filtered #yiv9524372747 {font-family:Wingdings;} _filtered #yiv9524372747 {font-family:Wingdings;} _filtered #yiv9524372747 {font-family:Wingdings;} _filtered #yiv9524372747 {font-family:Wingdings;} _filtered #yiv9524372747 {font-family:Wingdings;} _filtered #yiv9524372747 {font-family:Wingdings;}#yiv9524372747 ol {margin-bottom:0cm;}#yiv9524372747 ul {margin-bottom:0cm;}#yiv9524372747 Hi Alvaro, Your idea looks very promising and I could probably think of a situation or two where this would be very useful. I wonder though, why only allow a map to sync with the other maps and not sync to a specific map? If I could sync to a specific map, I would be able to setup four maps where they sync in pairs. Regards, Casper From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org]On Behalf Of A Huarte
Sent: 25. august 2016 23:49
To: Tim Sutton
Cc: QGIS Developer Mailing List
Subject: Re: [Qgis-developer] QEP about Multimap support for QGIS Thanks Tim! You are right, there will be many code with this assumption. It is true that I have only reviewed the main tools in QGIS, but these changes have been small or zero. At least we can know with this commit the amount de changes to do in the main application (100 files edited, some of them with minimum changes). Regards Alvaro De: Tim Sutton <tim at kartoza.com>
CC: Filipe Dias <filipesdias at gmail.com>; QGIS Developer Mailing List <Qgis-developer at lists.osgeo.org>
Enviado: Jueves 25 de agosto de 2016 21:13
Asunto: Re: [Qgis-developer] QEP about Multimap support for QGIS Hi Alvaro I also think this would be very interesting to add - and timely to get into QGIS 3.0. Looking forward to hearing opinions from other devs. I expect there will be many many corner cases you will have to deal with where there is currently an implicit assumption that only 1 canvas exists.... Regards Tim
On 25 Aug 2016, at 11:31 AM, A Huarte <ahuarte47 at yahoo.es> wrote: Thank you very much Filipe! The extra maps are normal windows as any dockable window in QGIS. It is a QDockWidget object, and your behavior is as usual.
Best regards Alvaro De: Filipe Dias <filipesdias at gmail.com>
CC: "Qgis-developer at lists.osgeo.org" <Qgis-developer at lists.osgeo.org>
Enviado: Jueves 25 de agosto de 2016 9:39
Asunto: Re: [Qgis-developer] QEP about Multimap support for QGIS Hi, Really nice feature in my opinion. Out of curiosity: would it be possible to split Map 1 and Map 2 between two different screens? It would be really nice to be able to drag Map 2's window to a second screen. Thanks Cheers On Thu, Aug 25, 2016 at 2:36 AM, A Huarte<ahuarte47 at yahoo.es> wrote:
Hi devs, I have developed an experimental code to support more than one map in QGIS. I created a video showing the features implemented (https://vimeo.com/179982647 ). The main features are:
- New user option to enable multi map canvas mode.
- QGIS has one no closeable default map, and 0-N extra dockable maps.
- Full integration of maps in legend using a new map legend node for each map.
- Print composer supports layouts with different maps.
- New legend menu option to synchronize the extent of maps.
- Map tools and plugins work with the current selected map (The signals and slots to the map canvas are updated with an automatic mechanism of synchronization to minimize the migration of code and to preserve behavior).
I'm aware that this is a big change in QGIS, and I am sure that this capability must be debated by many people (project and developer leaders...) before writing any code. Because of that, I have not created any QEP entry in the https://github.com/qgis/ QGIS-Enhancement-Proposals page. I developed it to learn QGIS core and it will have work to do (plugins and tools). But it runs fine, and it was funny :-). If at least, it is useful for a day to implement this capability in QGIS or to see the amount of changes needed, I am satisfied. github: https://github.com/qgis/QGIS/ compare/master...ahuarte47: Feature_MultimapView video: Multi Map Canvas for QGIS
| Multi Map Canvas for QGIS |
| Ver envimeo.com | Vista previa por Yahoo |
Comments are welcome! Best regards Alvaro Huarte - https://github.com/ahuarte47
______________________________ _________________
Qgis-developer mailing list
List info: http://lists.osgeo.org/ mailman/listinfo/qgis- developer
Unsubscribe: http://lists.osgeo.org/ mailman/listinfo/qgis- developer _______________________________________________
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton Co-founder: Kartoza Project chair: QGIS.org Visit http://kartoza.com to find out about open source: Desktop GIS programming services Geospatial web development GIS Training Consulting Services Skype: timlinux IRC: timlinux on #qgis at freenode.net Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160829/13b1b278/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160829/13b1b278/attachment-0001.jpg>
