[Qgis-developer] Processing: fixed, variable, and percentage buffer
Nyall Dawson
nyall.dawson at gmail.com
Thu Dec 1 03:14:46 PST 2016
On 1 Dec 2016 8:47 PM, "Paolo Cavallini" <cavallini at faunalia.it> wrote:
Hi all,
with the recent addition of expressions as parameters, I think variable
buffer alg is a duplication of the fixed one, which should be renamed in
a generic "Buffer": am I wrong?
BTW: also Percentage buffer can be done with the same technique, so the
plugin[0] will possibly be useless.
Unsure about other plugins[1]: possibly these coud be unified as well?
Probably for the average user having to enter expression for this could
be intimidating at first: what about having a set of predefined expressions?
I've been thinking about something similar to the data defined buttons used
by symbology. Ie default to a constant value input, but using a custom
widget you can choose to use a fields value or a custom expression.
Nyall
All the best, and thanks.
[0]
http://plugins.qgis.org/plugins/BufferByPercentage/
[1]
http://plugins.qgis.org/plugins/Multi_Ring_Buffer/
http://plugins.qgis.org/plugins/MultiDistanceBuffer/
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161201/af43bc49/attachment.html>
