[Qgis-developer] how to turn my plugin into a processing subplugin
Julie Pierson julie.pierson at cnrs.fr
Fri Dec 2 00:57:10 PST 2016
Thanks to all for your answers, it's great to get good advice quickly.
It's more clear to me now how to proceed, I'll give it a try !
Julie.
Le 02/12/2016 à 08:16, Victor Olaya a écrit :
> If you convert your plugin functionality into Processing scripts, then
> it's very easy to distribute them, no need create a plugin manually
> and add them to it.
> Just create your scripts and make sure they are available in the
> toolbox. Then, in the "Scripts" group of the toolbox, you will find a
> tool called "Create script collection plugin". Just select the scripts
> that you want to distribute, and it will package them into a plugin
> that you can share in the plugins server. Installing the plugin will
> add the scripts to the toolbox.
> Hope this helps
> 2016-12-01 22:25 GMT+01:00 Nyall Dawson <nyall.dawson at gmail.com>:
>> On 29 Nov 2016 1:22 AM, "Julie Pierson" <julie.pierson at cnrs.fr> wrote:
>> Hi all,
>> I would like to answer this issue for my plugin :
>> https://github.com/UMR-PASSAGES/DissolveWithStats/issues/2, and turn it into
>> a processing subplugin. I read this :
>> https://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/processing.html,
>> but I'm still not sure how to go on.
>> I'm guessing that my script will be accessible from the Scripts/Tools part
>> of the processing toolbox. But I don't understand :
>> - where these scripts are hosted, and how do I submit it
>> - where do I start ? Should I just make  a new version of my plugin without
>> the GUI ?
>> Have a look at
>> https://github.com/jdugge/BufferByPercentage/commit/c52d161b40abf6bbd45e7ec421eb311623592e90
>> That's a similar commit which added a processing module to an existing
>> plugin.
>> The hardest(?) part is refactoring your plugin to split all the logic out
>> from any existing gui. Buts that's a good thing to do in any case.
>> Nyall
>> Sorry if the answers are obvious !
>> Thanks,
>> Julie.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
