[Qgis-developer] Any UI/UX plans for QGIS3?
Alexandre Neto
senhor.neto at gmail.com
Sat Dec 3 03:31:20 PST 2016
A sáb, 3/12/2016, 03:54, Nyall Dawson <nyall.dawson at gmail.com> escreveu:
> Here's another idea for a great project t which doesn't involve
> c++/python: check through and delete unused png icons.
> A lot of the old png icons have been replaced with proper svg versions,
> but the pngs are still included and in some cases they are incorrectly used
> instead of the svg replacements.
> Identifying these would be a matter of going though each png icon in the
> repo and searching through the code (eg via "git grep mactionrefresh.png")
> to see if they are still used anywhere. (Ignore any hits in the resources
> files!) . If they aren't they can be safely removed. If they are, you could
> check whether a suitable svg replacement can be used.
> The more pngs we remove the easier it will be to identify which remaining
> icons require vector versions.
> Nyall
Great one. I will add it to the QGIS 3 UIX issues repo.
I like the idea of having easy to follow instructions in the issue for
anyone to pick it up and solve.
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161203/1364a457/attachment.html>
