[Qgis-developer] PyQgsAuthManagerPKIOWSTest disabled on Travis
Nyall Dawson
nyall.dawson at gmail.com
Sun Dec 4 16:27:45 PST 2016
Following the conversation from
https://github.com/qgis/QGIS/commit/89d4998 , this is an announcement
to notify that the PyQgsAuthManagerPKIOWSTest has been disabled on the
Travis builds.
Work has been underway to remove "noisy" tests from Travis which cause
false alarms and these tests regularly fail for unrelated changes.
False alarms are bad as they undermine confidence in the CI results
and encourage contributors to ignore the test results.
If you're interested in seeing these tests continue as part of the CI
infrastructure here's an example of the test failing on an unrelated
commit:
https://travis-ci.org/qgis/QGIS/builds/181213418
Nyall
