[Qgis-developer] Add virtual layer equivalent in Processing
Victor Olaya volayaf at gmail.com
Sun Dec 4 23:51:28 PST 2016
No, there is no such functionality AFAIK, but it should be easy to add, i think
Can you open a feature request?
Also, the execute SQL algorithm can be modified to accept non-spatial
tables. That makes sense to me
Cheers
2016-12-04 22:28 GMT+01:00 Anita Graser <anitagraser at gmx.at>:
> Hi,
> Since the user list doesn't seen to have an answer, I'd like to ask here:
> Is there an equivalent to the "add virtual layer" functionality in the
> Processing toolbox?
> I want to join multiple csv files to a vector layer (and at the same time
> build a new geometry WKT). This seems most easily done with a virtual layer.
> But I need to script this workflow.
> In the Processing toolbox, I only found the "execute SQL" tool but it does
> not allow selection of non-spatial tables as input.
> Best wishes,
> Anita
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
