[Qgis-developer] Add virtual layer equivalent in Processing
Victor Olaya
volayaf at gmail.com
Mon Dec 5 04:54:02 PST 2016
Anita, Mathieu
I added both of your requests and it should be possible now to use
tables on both "execute SQL" and "build virtual vector" algorithms
Let me know if you try it (it is on master)
Cheers
2016-12-05 11:07 GMT+01:00 Mathieu Pellerin <nirvn.asia at gmail.com>:
> Victor,
> I was looking into this; it'd be nice for the "build vector layer" algorithm
> would support/show geometryless layers in the parametermultiinput panel.
> AFAIK, geometryless layers aren't (yet? :) ) supported by the
> parametermultiinput.
> Math
> On Mon, Dec 5, 2016 at 2:51 PM, Victor Olaya <volayaf at gmail.com> wrote:
>> No, there is no such functionality AFAIK, but it should be easy to add, i
>> think
>> Can you open a feature request?
>> Also, the execute SQL algorithm can be modified to accept non-spatial
>> tables. That makes sense to me
>> Cheers
>> 2016-12-04 22:28 GMT+01:00 Anita Graser <anitagraser at gmx.at>:
>> > Hi,
>> > Since the user list doesn't seen to have an answer, I'd like to ask
>> > here:
>> > Is there an equivalent to the "add virtual layer" functionality in the
>> > Processing toolbox?
>> > I want to join multiple csv files to a vector layer (and at the same
>> > time
>> > build a new geometry WKT). This seems most easily done with a virtual
>> > layer.
>> > But I need to script this workflow.
>> > In the Processing toolbox, I only found the "execute SQL" tool but it
>> > does
>> > not allow selection of non-spatial tables as input.
>> > Best wishes,
>> > Anita
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
