[Qgis-developer] Processing NG/V2 - brainstorming
Nyall Dawson nyall.dawson at gmail.com
Mon Dec 5 15:00:32 PST 2016
On 6 December 2016 at 05:46, Matthias Kuhn <matthias at opengis.ch> wrote:
> Thanks for writing this up Nyall,
> This is something that I has been on my list of ideas for a long time
> already and that I have never got round to get down to.
> I think you have covered the topic quite well already, so I don't think
> there's a lot I have to add right now.
Ah - that reminds me of point 4 which I forgot:
4 - Make more use of iterators in QGIS api
What I mean here is that things like QgsVectorFileWriter,
QgsVectorDataProvider, QgsVectorLayer should all have an addFeatures(
QgsFeatureIterator it... ) method to make it easier to bulk insert
features.
There's also the possibility of adding a "QgsFeatureIteratorProvider"
interface which implements a getFeatures() call. QgsVectorLayer would
then implement the interface, as well as other classes like
QgsFeatureList and QgsFeatureStore, and the processing algorithms.
Nyall
> On 12/05/2016 06:41 PM, Alexander Bruy wrote:
>> Regarding iterators approach... It sounds interesting, but we need to think
>> also about possibility to work with layers, which are not loaded in QGIS.
>> In this case as I understand we need to construct layer and then create
>> an iterator for Processing from it.
> If the algorithm is a QGIS core one, that's correct. But I assume that's
> done already now, so it shouldn't be much of a difference.
> For anything else, the iterator approach will not be usable either way
> and it will have to end up in a file anyway. So the model processor
> should be smart enough to handle that.
> Case 1:
> qgis alg -> qgis alg
>   iterator
> Case 2:
> qgis alg -> external alg
>   find a suitable file format and route the iterator to this file
> Case 3:
>   external alg -> external alg
> check if they have a common file type, if yes, use it, if not convert
> between something usable.
> If an external file is involved as source, a "file loader" algorithm
> should be transparently inserted to handle conversion to an iterator or
> find the best intermediate format or just pass the file as-is.
>> Another idea (obvious and already discussed a bit) is to adopt Processing
>> to use recently added Task Manager, so algs can be executed in background
>> and models can be executed using multiple threads when this is possible.
> I think that's something that will happen in any case. We should be able
> to combine the two ideas.
> The different possibilities here are probably:
> * Always use a file to pass data between algs:
>     Heavy on disk I/O and which has performance impacts.
> * Use a memory layer to pass data between algs:
>     Heavy on memory which may fail with big data (*)
> * Iterator approach:
>     Performance win. Most complex because it adds a lot of
> task-interdependency, scheduling effort and possibly will still use a
> lot of memory if the consumer algorithm is not fast enough to handle the
> data produced by the generator algorithm. So there should be some kind
> of coordination between the iterator and the producer to pause the
> producer task if the queue gets too big.
> Best regards
> Matthias
> (*) I always like to use the term big data. It makes me feel like a
> sales person.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
