[Qgis-developer] QGIS Custom Widget in Qt Designer
Marco Bernasocchi marco at opengis.ch
Wed Dec 7 11:45:20 PST 2016
Hi Denis,
I was just put of by the fact that the xml tag is called customwidget.
They are in fact promotet widgets. And I really wonder how this can work.
Could you try the resource sharing plugin. Does it work for you?
Ciao
On 8 December 2016 02:16:55 GMT+13:00, Rouzaud Denis <denis.rouzaud at gmail.com> wrote:
>Hi Marco,
>This doesn’t sound like a QGIS custom widget issue since QWebView is
>not related to QGIS.
>It seems that QWebView is well defined in PyQt4 compatibility layer
>[0].
>The issue is probably that you try to run system uic instead of
>qgis.PyQt.uic.
>This make me thunk of the reply to Matteo as well….try to run
>qgis.PyQt.uic instead of uic
>I hope this helps
>Denis
>[0]
>https://github.com/qgis/QGIS/blob/release-2_18/python/PyQt/PyQt4/QtWebKitWidgets.py#L32
><https://github.com/qgis/QGIS/blob/release-2_18/python/PyQt/PyQt4/QtWebKitWidgets.py#L32>
>> On 7 Dec 2016, at 12:51, Marco Bernasocchi <marco at opengis.ch> wrote:
>> Salut Denis,
>> I'm a bit lost, I see in plugins like the resources sharing tool [0]
>> <customwidgets>
>>  <customwidget>
>>   <class>QWebView</class>
>>   <extends>QWidget</extends>
>>   <header>QtWebKitWidgets/QWebView</header>
>>  </customwidget>
>> </customwidgets>
>> and when I install the plugin I see:
>> This plugin is broken
>> No module named QtWebKitWidgets.QWebView
>> this plugins also use the uic.loadUi approach
>> I've qgis installed from packages and also self build:
>> marco at placebo:~/dev/QGIS/master/python/custom_widgets$ locate
>> libqgis_customwidgets.so
>/usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libqgis_customwidgets.so
>/usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libqgis_customwidgets.so.2.18.1
>> qgis_customwidgets.py
>/home/marco/dev/QGIS/master/python/custom_widgets/qgis_customwidgets.py
>/home/marco/gis_data/pacsafe/QGIS/python/custom_widgets/qgis_customwidgets.py
>/usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/qgis_customwidgets.py
>/usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/qgis_customwidgets.pyc
>> Am I missing some magic somewhere? QtWebKitWidgets exists only from
>Qt5.
>> in Qt4 it should still be QtwebKit.
>> ciao
>> Marco
>> [0]
>https://github.com/akbargumbira/qgis_resources_sharing/blob/master/resource_sharing/gui/ui/resource_sharing_dialog_base.ui#L598
>> On 07.12.2016 22:58, Denis Rouzaud wrote:
>>> Hi Matteo,
>>> The file is not present simply because you did not install QGIS.
>>> See here
>https://github.com/qgis/QGIS/blob/master/python/CMakeLists.txt#L287
>>> Having it documented somewhere would be nice:
>>> * Approach when installing
>>> * Without installing: were to put libqgis_customwidget and
>>> qgis_customwidgets.py, how to run pyuic.
>>> Cheers,
>>> Denis
>>> On 12/07/2016 10:41 AM, matteo wrote:
>>>> Hold on.. I should have manage it..
>>>> I discovered that my machine was missing the file
>>>> in the folder
>>>> in another machine I found that file and I copied it in the right
>folder
>>>> (the above one) and now it seems working, that is the plugin with
>the
>>>> custom widget is now correctly loaded without any more issues..
>>>> So many thanks Denis for the assistance..
>>>> My question is now.. why was that file missing in the folder?
>>>> In the other machine I ran Ubuntu and I was used to compile QGIS
>with
>>>> debian rules.
>>>> In this new machine I compile QGIS with make and run it directly
>from
>>>> the output folder (so QGIS has never been installed with repository
>>>> packages and/or deb files, don't know if this could be related to
>the
>>>> problem)
>>>> I have some confusion on my mind..
>>>> If this is worth I can put this solution (if you think it is a
>solution
>>>> and not a workaround) somewhere in the website or another place so
>that
>>>> other people facing the same problem could solve the issue.
>>>> Many many thanks to all
>>>> Matteo
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Marco Bernasocchi
>> OPENGIS.ch - berna.io - 27summits.ch
Marco Bernasocchi (mobile).
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161208/df24a566/attachment.html>
