[Qgis-developer] Field mapper when pasting features
Arnaud Morvan
arnaud.morvan at camptocamp.com
Thu Dec 8 02:23:01 PST 2016
Hi Saber,
Yes, I will try to spent some time on this in Lyon next week.
Cheers
Arnaud Morvan
Ingénieur logiciel
Tél: +33 (0)4 58 48 20 32
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
http://www.camptocamp.com
Le 08/12/2016 10:36, Saber Razmjooei a écrit :
> Hi Arnaud,
> As suggested by others, a QEP for mapping fields would be great. Some
> of the Processing tools (e.g. merging layers) can also benefit from that.
> Cheers
> Saber
> *From:*Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org]
> *On Behalf Of *Denis Rouzaud
> *Sent:* 01 November 2016 08:02
> *To:* Arnaud Morvan; qgis-developer
> *Subject:* Re: [Qgis-developer] Field mapper when pasting features
> Hi Arnaud,
> I am really looking forward to seeing such feature implemented in
> QGIS, thanks for bringing up the discussion.
> I would also recommend going for a QEP, as it is a largely foreseen
> feature, and I suppose everyone has its own definition and use-case...
> From my point of view, we should go for a very generic field-mapping
> mechanism which could be used in many places such as copy-paste. A way
> of reading/saving configuration would be quite useful, like presets.
> Best wishes,
> Denis
> On 10/27/2016 05:52 PM, Arnaud Morvan wrote:
> Hello QGIS devs,
> I want to add a field mapper dialog when pasting features to layers.
> For now when pasting features with attributes names that do not
> exists on the destination layer,
> those attributes values are lost.
> When clipboard fields and destination layer fields are not
> strictly the sames,
> In QGIS 3.0, I want to popup a new dialog with fields mapper
> configurator.
> Dialog UI could be similar to Refactor Fields Algorithm, showing a
> list of destination fields :
> source expression (expression widgets) => destination field
> For example, I often use this workflow :
> Open a shapefile or autocad file.
> Use the refactor fields to get temporary layer with same
> fields as destination.
> Paste to postgis database layer.
> I think having this dialog showing up when needed could really
> ease data manipulation from one layer to another.
> And I want to give the possibility to use expressions.
> Any remarks, do you think I need to open to open a QEP for that ?
> Regards
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed. If you have received this email in error please notify
> the system manager. This message contains confidential information and
> is intended only for the individual named. If you are not the named
> addressee you should not disseminate, distribute or copy this e-mail.
> Please notify the sender immediately by e-mail if you have received
> this e-mail by mistake and delete this e-mail from your system. If you
> are not the intended recipient you are notified that disclosing,
> copying, distributing or taking any action in reliance on the contents
> of this information is strictly prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to
> carry out such checks as you feel appropriate.
> If this email contains a quote or offer to sell products, carry out
> work or perform services then our standard terms and conditions
> <http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf>
> shall apply unless explicitly stated otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161208/bdab180c/attachment-0001.html>
