[Qgis-developer] should core plugins not be available in plugin manager?
Victor Olaya volayaf at gmail.com
Mon Dec 12 06:32:51 PST 2016
> Only issue I see (and the reason I disable processing sometimes) is the
> brokeness of some providers when I mix and match versions of QGIS, or run
> older (compiled) versions of QGIS.
A good reason to have providers as independent plugins, as I proposed
in another email :-) You should be able to disable providers, but not
the Processing framework itself.
