[Qgis-developer] should core plugins not be available in plugin manager?
Marco Bernasocchi
marco at opengis.ch
Mon Dec 12 23:39:32 PST 2016
A core plugin can be python as well.
Ciao
On 13 December 2016 08:14:46 CET, Andreas Neumann <a.neumann at carto.net> wrote:
>Ok - thanks for clarifying.
>What's the difference between a core C++ plugin and a C++ plugin?
>Is the only difference that the core plugins are shipped and enabled by
>default?
>Andreas
>On 13.12.2016 08:09, Nathan Woodrow wrote:
>> To be clear this isn't removing the ability to have C++ plugins, just
>> having core plugins and making them optional.
>> - Nathan
>> On Tue, Dec 13, 2016 at 5:08 PM, Neumann, Andreas
>> <mailto:a.neumann at carto.net>> wrote:
>> Hi,
>> Before we remove the ability to have C++ plugins, or the ability
>> to enable/disable them, we should first inform our users and
>> developers and ask them if we are fine with what we propose.
>> There may be usages of QGIS out there that rely on the ability to
>> have C++ plugins that we are not aware of.
>> I do agree though that some core plugins could be removed or
>> integrated into the core. One example is the coordinate capture
>> plugin, which could be easily integrated in core, e.g. integrated
>> in the identify tool or status bar.
>> Probably the EVIS plugin is another candidate with lots of
>> overlaps. If we add the missing functionality the EVIS plugin
>> provides to core, we could get rid of it.
>> Andreas
>> On 2016-12-12 20:57, DelazJ wrote:
>>> Hi,
>>> I do not fully share the agreement on having core plugins not
>>> deactivable. Are Core plugins the problem or is it Processing?
>>> Let's not wrongly mix issues.
>>> I'd always thought that Core plugins meant plugins developed,
>>> managed, updated by the QGIS project itself, provided by default
>>> with installation. It doesn't mean that everybody wants to use
>it
>>> or needs it. The Road Graph is a plugin I had never executed in
>5
>>> years I'm using QGIS. Many others (GPS Tools, Heatmap, rasters
>>> related plugins...) are concerned. Why would I want it activated
>>> by default and crowd the GUI? Then I'd have to struggle and
>>> change some somehow hidden customization option to have it
>>> disabled? Uncheck it in Plugin Manager sounds far simpler.
>>> What puzzled many users (and might still do) with Processing in
>>> QGIS >=2.16 is to have removed fTools and not activate
>Processing
>>> by default for those that were using fTools. They should be
>>> provided a transparent replacement of fTools (including the
>>> removal of this one from the list).
>>> And maybe communication about this change is not clear for all
>>> people. Currently, fTools state is broken but there's no message
>>> to tell you that you should instead activate Processing to get
>>> back your lovely functions.
>>> So, from me, no, Core plugins should stay (de)activable even
>>> though looking at all the list of Core plugins being integrated
>>> in Processing in 3.0 I wonder how many Core plugins will stay
>(DB
>>> Manager and Processing?) when 3.0 lands. :)
>>> Also, one of the power of QGIS imho is its modularity: you pick
>>> what you need. We should not put all in one. And having Core
>>> plugins being listed there gives some kind of confidence to
>>> contributors to follow the path (create plugins). I'm not sure i
>>> well expressed what I meant to.
>>> Regards,
>>> Harrissou
>>> 2016-12-12 16:01 GMT+01:00 Martin Dobias <wonder.sk at gmail.com
>>> <mailto:wonder.sk at gmail.com>>:
>>> Hi Victor
>>> On Mon, Dec 12, 2016 at 7:05 PM, Victor Olaya
>>> <volayaf at gmail.com <mailto:volayaf at gmail.com>> wrote:
>>> > Hi
>>> > This has been discussed in the past, but i think no
>>> decision was
>>> > taken, so I want to bring back the discussion.
>>> > I think that core plugins should not be visible in the
>>> plugin manager,
>>> > and users should not be able to disable them. If they are
>>> core, they
>>> > should be active (the menus and buttons can be removed
>with the
>>> > "View/Customization..." functionality if the user wants
>to)
>>> Agreed that Processing should be always on. Also, IMO it
>>> should be
>>> available as "qgis.processing" python module.
>>> Cheers
>>> Martin
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> <mailto:Qgis-developer at lists.osgeo.org>
>>> List info:
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>> Unsubscribe:
>>> List info:
>>> Unsubscribe:
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:
>Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Marco Bernasocchi (mobile).
OPENGIS.ch - berna.io - 27summits.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161213/df97d4da/attachment-0001.html>
