[Qgis-developer] Do Python plugins already work with QGIS 3?
Andreas Neumann a.neumann at carto.net
Tue Dec 13 07:23:41 PST 2016
I get a message:
Unable to load GdalTools plugin.
The required "osgeo [python-gdal]" module is missing.
Install it and try again.
then there is a new error message:
ImportError: No module named 'osgeo'
I installed gdal from source, but enabled Python and also enabled shared
libraries.
Could it be that gdal was compiled with Python 2 while QGIS runs with
Python 3?
If that's the case, how can i compile GDAL with Python 3 support?
Can I compile gdal with Python 2 and 3 support if I want QGIS 2.x and
3.x on the same machine?
Thanks,
Andreas
On 13.12.2016 15:55, Tom Chadwin wrote:
> Define "fail", I guess. Most plugins won't work without modification
> [citation needed], but it would be good to know *how* it fails, as you are
> right that there could be a more general issue.
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Do-Python-plugins-already-work-with-QGIS-3-tp5299693p5299694.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161213/668332fb/attachment-0001.html>
