[Qgis-developer] Do Python plugins already work with QGIS 3?
Andreas Neumann
a.neumann at carto.net
Tue Dec 13 08:00:06 PST 2016
Hi Marco,
Thanks - this helped a lot. Apparently it was the missing python3-gdal
bindings. I only had the bindings for python2. Processing now seems to
work fine (at least the few tests I did).
However, db manager still fails to start with error message:
2016-12-13T16:53:21 1 Traceback (most recent call last):
File
"/usr/local/share/qgis/python/plugins/db_manager/db_manager_plugin.py",
line 108, in run
from .db_manager import DBManager
File "/usr/local/share/qgis/python/qgis/utils.py", line
647, in _import
mod = _builtin_import(name, globals, locals, fromlist,
level)
File
"/usr/local/share/qgis/python/plugins/db_manager/db_manager.py", line
36, in <module>
from .layer_preview import LayerPreview
647, in _import
level)
File
"/usr/local/share/qgis/python/plugins/db_manager/layer_preview.py", line
27, in <module>
from qgis.gui import QgsMapCanvas, QgsMapCanvasLayer,
QgsMessageBar
ImportError: cannot import name 'QgsMapCanvasLayer'
Can you confirm that DB-manager should work fine with the latest master?
Thanks,
Andreas
On 13.12.2016 16:40, Marco Bernasocchi wrote:
> could be,
> it could also be a PYTHONPATH issue depenndign where you installed the
> bindings.
> can you import them in a python prompt?
> to build gdal with python 3 you need to do some thing like:
> cd gdal/swig/python
> python3 setup.py build & python3 setup.py install
> IIRC gdal compiles in its source dir so for qgis for android I just used
> to copy the whole GDAL folder before building to keep a clean copy.
> more info:
> https://trac.osgeo.org/gdal/wiki/GdalOgrInPython
> https://trac.osgeo.org/gdal/wiki/BuildingOnUnix
> ciao
> Marco
> On 13.12.2016 16:23, Andreas Neumann wrote:
>> Hi,
>> I get a message:
>> Unable to load GdalTools plugin.
>> The required "osgeo [python-gdal]" module is missing.
>> Install it and try again.
>> then there is a new error message:
>> ImportError: No module named 'osgeo'
>> I installed gdal from source, but enabled Python and also enabled shared
>> libraries.
>> Could it be that gdal was compiled with Python 2 while QGIS runs with
>> Python 3?
>> If that's the case, how can i compile GDAL with Python 3 support?
>> Can I compile gdal with Python 2 and 3 support if I want QGIS 2.x and
>> 3.x on the same machine?
>> Thanks,
>> Andreas
>> On 13.12.2016 15:55, Tom Chadwin wrote:
>>> Define "fail", I guess. Most plugins won't work without modification
>>> [citation needed], but it would be good to know *how* it fails, as you are
>>> right that there could be a more general issue.
>>> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
>>> View this message in context: http://osgeo-org.1560.x6.nabble.com/Do-Python-plugins-already-work-with-QGIS-3-tp5299693p5299694.html
>>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
