[Qgis-developer] Do Python plugins already work with QGIS 3?
Andreas Neumann
a.neumann at carto.net
Tue Dec 13 08:09:06 PST 2016
yes - I used the instructions from
https://github.com/qgis/QGIS/blob/master/INSTALL
but all "geo" libraries (geos, gdal, spatialite, postgres/postgis) had
been installed from source.
Is there a dependency python module list for db manager available?
python3-psycopg is installed. Any other SQL modules or other modules the
DB manager requires?
Andreas
On 13.12.2016 17:02, Paolo Cavallini wrote:
> Il 13/12/2016 17:00, Andreas Neumann ha scritto:
>> Can you confirm that DB-manager should work fine with the latest master?
> I confirm. Probably other py3 packages are missing.
> Did you insall what is in the requirements?
> All the best.
