[Qgis-developer] Listener for Atlas Change Page
Shawn Tse shawntse at gmail.com
Tue Dec 13 19:42:41 PST 2016
Thanks, that looks like exactly the kind of function that I'm looking
for. I'm using QGIS 2.18.0, I'm wondering, is there any way to use
this function without having to select a menu item in the the plugin?
I'm not sure how to get started, because most of the existing plugins
seem to be activated by a menu item or a toolbar button in the main
editor instead of via the atlas interface.
Thank you and I really appreciate the help!
On Mon, Dec 12, 2016 at 11:02 PM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On 13 Dec 2016 4:44 PM, "Shawn Tse" <shawntse at gmail.com> wrote:
> Hi all,
> I'm interested in being able to make graphs that update depending on
> what the active feature in the atlas is. I know some python and a
> little bit of the QGIS API, but I'm curious - is there some sort of
> listener function for the atlas that gets called whenever the Preview
> Atlas/Prev Feature/Next Feature/First Feature/Last Feature buttons are
> pressed?
> Try QgsAtlasComposition::featureChanged. See
> https://qgis.org/api/classQgsAtlasComposition.html#ab1a15fdb6d20ebb1254ebb6714254fac
> Nyall
> What I eventually want to do is to manipulate the node items that were
> created in a recent updated version of QGIS, and use them to make a
> line graph, gridlines, etc.
> I'm hoping to draw the data directly from the shapefiles themselves or
> from a .csv file.
> I originally tried to use an expression in a text box to do this, but
> it seems that expressions are unable to use custom functions to
> manipulate the composer. So I'm hoping that there's some sort of
> Listener method.
> Thanks.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
