[Qgis-developer] Plugin [1102] AequilibraE approval notification.
Matthias Kuhn
matthias at opengis.ch
Mon Dec 19 04:21:17 PST 2016
So, the security concern is, that there might be malicious code in
there? In case of the sourcecode provided alongside the binary, assuming
that potentially the binary might not match the provided code?
Possibilities I see:
1) Trust was also the reason for introducing the "trusted author" flag.
So maybe we could just build on the same fundament (e.g. require
sourcecode always to be present, trust "trusted authors" that their
binary matches the code, show a carefully worded warning, that the
plugin contains binary libraries provided by "X" and that the user
should only install this plugin if he fully trusts "X".).
2) The other way I see is to completely prohibit shipping binaries
through our own plugin server. Accepting that plugin devs start to ship
their plugins over other infrastructures which results in more
fragmentation.
3) Or the third way of offering "code review and signing services" but
that will be a lot of work to put into place, maintain and result in a
system which is exclusionary to small providers.
4) Or putting our own "build servers" into place, where you can upload
source code, the server will compile it and this way make sure, that
code and binary match. But given that we have already been dealing with
java and cython this morning, and that there are a bazillion other
languages out there, that's not gonna be easy.
5) And finally have an official statement that plugins can be shipped
through the official repo but that plugins should download compiled libs
from a 3rd party page.
I would propose to keep the barrier low, given that the security gain by
any of the systems is actually very low (except for a very restrictive
implementation of 3) which is also maintenance expensive). We probably
have to accept that we do not have the power to prevent anything bad
happening.
Personally I would just go a pragmatic way of 1) delegating trust to the
authors and keep plugins on our infrastructure, where we can also nicely
ask people to also upload the code to comply with the GPL.
Regards
Matthias
On 12/19/2016 12:49 PM, Luigi Pirelli wrote:
> In this case the problem is security
> code is available and compiled for most used platforms... but hard to
> certify the content of the so/dll.
> any opinion?
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> * https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> On 19 December 2016 at 09:40, Matthias Kuhn <matthias at opengis.ch> wrote:
>> Hi all
>> What's the main goal? Code availability? Security? Platform independency?
>> Just curious.
>> All the best
>> Matthias
>> On December 19, 2016 9:25:29 AM GMT+01:00, Luigi Pirelli <luipir at gmail.com>
>> wrote:
>>> Hi Pedro,
>>> Nothing personal, your case is a common case due the fact to many
>>> cases where to integrate external executables or shared objects.
>>> we can have a way to certificate this binary (e.g. signing process but
>>> could become harder develop plugins, checksums). In the meantime, I
>>> strongly suggest to a have a two phase plugin. A first phase that
>>> prepare running environment downloading so or dll from someware with
>>> the user consensous, and then the running phase.
>>> in this way you can facilitate users to access plugin thanks to qgis
>>> repo, and turn around plugin limitations that community gave for user
>>> security.
>>> regards
>>> Luigi Pirelli
>>> On 19 December 2016 at 08:25, Pedro Camargo <veigacamargo at gmail.com>
>>> wrote:
>>>> Hi Luigi and Paolo,
>>>> I corrected the problems you pointed out with AequilibraE and
>>>> re-uploaded it.
>>>> Luigi's concern with malicious code is a very valid one, and I would
>>>> actually appreciate to have a manner to have it checked. However, I
>>>> would
>>>> appreciate if we could find a solution that does not prevent us from
>>>> having
>>>> plugins that are compiled.
>>>> As Luigi pointed out, the code is written in Cython to increase
>>>> performance
>>>> of the software, but it is still 5.5x slower than the proprietary
>>>> software
>>>> that I used as a benchmark. In a nutshell, if it cannot be compiled, it
>>>> will
>>>> never fly. So I would ask you guys to be considerate of this point.
>>>> My concerns might not even be valid, and I do apologize if that is the
>>>> case.
>>>> I just must admit that, as an amateur software developer, I miss some of
>>>> the
>>>> jargon used here when talking about more technical issues on software
>>>> development.
>>>> Cheers,
>>>> Pedro
>>>> On Mon, Dec 19, 2016 at 7:18 AM, Luigi Pirelli
>>>> <luipir at gmail.com> wrote:
>>>>> Hi List
>>>>> The Binary problem (?):
>>>>> In this recently added plugin I can find cython modules precompiled in
>>>>> forms odf pyd, or so. (and relative cython code)
>>>>> Following the presentation in:
>>>>> https://www.youtube.com/watch?v=zz3jbM_JBTo
>>>>> I understand that the reason is performance, but how to prevent
>>>>> loading malicious shared objects?
>>>>> * probably we should start to plan a safe infrastructure to allow
>>>>> uploading plugin with compiled modules... any idea other than a simple
>>>>> checksum?
>>>>> The license problem (?):
>>>>> other question is regarding the cython algorithm. I can read in
>>>>> https://github.com/AequilibraE/AequilibraE/blob/master/aequilibrae/paths/AoN.pyx#L23
>>>>> "Codes for route ennumeration, DAG construction and Link nesting were
>>>>> written by Pedro Camargo (2013) and have all their rights reserved to
>>>>> the author"
>>>>> Obviously the author has right reserved, an in the same code the
>>>>> author refer to the LICENSE.txt that is a standard GPL license:
>>>>> here:
>>>>> https://github.com/AequilibraE/AequilibraE/blob/master/aequilibrae/paths/AoN.pyx#L18
>>>>> and here:
>>>>> https://github.com/AequilibraE/AequilibraE/blob/master/LICENSE.TXT
>>>>> how should we have to read the "right reserved" sencence by the author?
>>>>> regards
>>>>> Luigi Pirelli
>>>>> On 18 December 2016 at 14:28, <noreply at qgis.org> wrote:
>>>>>> Plugin AequilibraE approval by pcav.
>>>>>> The plugin version "[1102] AequilibraE 0.3.3" is now approved
>>>>>> Link: http://plugins.qgis.org/plugins/AequilibraE/
>>>>>> ________________________________
>>>>>> Qgis-developer mailing list
>>>>>> Qgis-developer at lists.osgeo.org
>>>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Sent from my Android device with K-9 Mail. Please excuse my brevity.
