[Qgis-developer] GDAL Tools: option missing
Giovanni Manghi giovanni.manghi at gmail.com
Thu Dec 22 03:09:49 PST 2016
> Hi Giovanni,
> thanks for checking. The command built by GDALTools is:
> gdal_grid -l test5 -zfield temp -a
> invdist:power=2:smothing=0:radius1=0:radius2=0:angle=0:max_points=0:min_points=0:nodata=0
> test5.shp
> and throws the error repoerted. From Processing the option is added:
> -ot Float32 test5.shp
Just tested on 2.18.2 on both Windows and Linux and cannot replicate
the problem.
In fact the command without the "-ot" parameter works just fine also
from the command line.
-- G --
