[Qgis-developer] QGIS3 crashes on startup
Matthias Kuhn matthias at opengis.ch
Thu Dec 22 03:26:49 PST 2016
On 12/22/2016 12:11 PM, Paolo Cavallini wrote:
> Il 22/12/2016 11:50, Richard Duivenvoorde ha scritto:
>> I'm also on Debian Testing here, and just recompiled last sources.
>> I cannot reproduce your crash.
>> Can you try with a clean config (use --configpath /tmp/foo),
>> or a clean compile?
> tried both, same result
> I'm on sid however, may be a different libQt5Widgets version?
> I have 5.7.1+dfsg-1
> thanks
Did you also try a clean build?
Matthias
