[Qgis-developer] QGIS3 crashes on startup
Richard Duivenvoorde
rdmailings at duif.net
Thu Dec 22 04:42:53 PST 2016
On 12/22/2016 12:11 PM, Paolo Cavallini wrote:
> Il 22/12/2016 11:50, Richard Duivenvoorde ha scritto:
>> I'm also on Debian Testing here, and just recompiled last sources.
>> I cannot reproduce your crash.
>> Can you try with a clean config (use --configpath /tmp/foo),
>> or a clean compile?
> tried both, same result
> I'm on sid however, may be a different libQt5Widgets version?
> I have 5.7.1+dfsg-1
apt search libQt5Widgets
Sorting... Done
Full Text Search... Done
libqt5widgets5/testing,now 5.7.1~20161021+dfsg-6 amd64 [installed,automatic]
Qt 5 widgets module
This is a different build only isn't it also 5.7.1 ?
I did a full clean build here, and still working
Richard
