[Qgis-developer] DWG/DXF Import on Linux
Jürgen E. Fischer
jef at norbit.de
Thu Dec 22 18:44:28 PST 2016
Hi Nyall,
On Fri, 23. Dec 2016 at 07:47:43 +1000, Nyall Dawson wrote:
> I think the dialog should also offer the option to create a new gpkg (or
> even better would be to change the output selector from an open file
> chooser to a save file chooser and mimic the current behaviour of the save
> vector dialog, where choosing to save using an existing filename gives
> options for overwriting or appending to the existing file).
If you specify a non existent geopackage it will be created. If you specify a
specify an existent file you can reload the drawing or choose other layers.
> - DWG input is called "Drawing". Could we call it "DWG drawing" ?
DWG is a abbrevation for drawing and it could also be a drawing in Drawing
eXchange Format (DXF).
> - Import step is triggered from inside the file dialog chooser, which is
> quite uncommon. It lets user think there is some freeze when in fact real
> work is being done
Actually that was the version before - essentially the same, just one click
less. But that was before there were options - now the previous version
would be preferable.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161223/f45f6d49/attachment.sig>
