[Qgis-developer] Testing new network analyses
Paolo Cavallini
cavallini at faunalia.it
Mon Dec 26 00:51:05 PST 2016
Hi Alex,
Il 26/12/2016 08:25, Alexander Bruy ha scritto:
> Here is short explanation from ArcGIS documentation
> http://desktop.arcgis.com/en/arcmap/latest/extensions/network-analyst/service-area.htm
> Also note that convex hull used only as example, you can get more
> accurate result
> using boundary points and apply more sophisticated algorithm to them.
thanks for this. got the issue: the travel cost parameter gets silently
zeroed if I edit the default 0 value. If I first delete the 0,000000
default value, then enter my param, it works fine. This is a general
issue with Processing, and I believe it's a true bug of Processing (user
inputs should never be discarded without consent).
BTW, what is the meaning of the `lower` polygon?
All the best, and thanks again.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
