[Qgis-developer] master python console bad autocomplete
Tudor Barascu tudorbarascu at yahoo.com
Thu Dec 29 03:55:21 PST 2016
Hi Alexander and thanks for the info.
>From what I noticed, the PyQgis.api is normally built every time but there's a corresponding pap file which the autocomplete is based on that doesn't get usually created.
In order to create that file there's a "make qsci-pap-src" option which seems to be broken on master.
Think Larry is more familiar with this part.
All the best,Tudor
    On Thursday, December 29, 2016 10:08 AM, Alexander Bruy <alexander.bruy at gmail.com> wrote:
 Hi Tudor,
AFAIK, autocompletion uses pre-generated API-files. Usually they updated
before release and not updated during dev cycle as some signatures may
change.
2016-12-28 20:21 GMT+02:00 Tudor Barascu <tudorbarascu at yahoo.com>:
> Hello,
> Just noticed that in the master python console some of the autocomplete
> suggestions are bad.
> For instance, although QgsDataSourceURI has been renamed to QgsDataSourceUri
> and the console suggests the first version which doesn't work.
> Shouldn't the suggestions be automatic?
> Thanks,
> Tudor
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161229/bb5e5892/attachment.html>
