[Qgis-developer] Improvements to the value relation widget: port to C++?
    Jeremy Palmer
    JPalmer at linz.govt.nz
    Tue Feb  2 03:08:09 PST 2016
> I would like to hear your thoughts about this.
I would find this useful it the widget could be enhanced to support dynamically fetching data from the underlying source based on input auto-complete filtering. A particular use case for me is using a large PostgreSQL table of millions of unique text code values.
Cheers
Jeremy
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
